  • Replies 92
check all your connectors from the coilpack out.
one could be dirty or corroded.
Maybe the CAS... but unlikely with your symptom... best case is to try someone elses CAS if you can...
erm... what else. Usual other stuff, clean AFM, new fuel filter
anything that might upset the fuel or spark is what you wanna chase
Plugs you say.
BCPR6E
They are a NGK V-groove 0.8mm gapped plug.
Thats the exact part number, don't go adding bits to it or changing it. They can be had from Motor traders/Coventrys for as little as $2.80 per plug. Buy else where and they might not have them and if they do you will be looking at $4.80 or something per plug.
Under full load/WOT... Have you checked your voltages? Maybe your Alt is on her merry way?
Has the motor been out of the car? Check all earths. Battery to chassis, battery to chassis to motor, all the little earth straps from the chassis to exhaust manifold, inlet manifold and head. Lots of little buggers around. Well there is on mine. ;)
OK So first thing
I read last night teh plug thing, and i was wondering what the differance is betweens i am running and the BCPR6E, i have also heard of BCPR6ES. I know NGK use to have a plug referance that told you what all the letter stood for, anyone have one? According to the NGK website the BKR6EYA are a direct replacemtn for iridiums that the car is suppose to have.???????
So i will try some of these plugs and see how it goes?
Injectors and clean, as best as i can tell, i checked all of trhem, flow almost all thesame, but i might try some good injector clener, what do you recomend?
I will do a log of the Voltages on teh way home, but as far as i know the alternator is ok, it never runs flat, voltage is 14.2 running, new battery, all seams ok, but will check it, Thanks.
The motor has not been out of the car, but i am not sure if all the earth are connected, as i don't know wher they all should be, will do some research.
In regards to R&R, no issues there, i can pull 13 psi before anythign flattens out, it's like a revlimmiter, not a cut out as such.
Going to do some more researching today.
Was told that a faulty CAS will do this aswell, can somone confirm and tell me what to look out for?
Do the R33 need a different spark plug????
DAM IT???
Funny thing is the problme was not there when car was STOCk it gradualy got worse the more mods i put onto the car. HUMMM...
May sound silly but are you sure you dont have a washer or something in the coilpack bay? I only ask coz thats what happened to me. After months of gapping and silicon, all it was, was a 2mm washer hiding in the well of cylinder 3
Will check it out, but i don't think there is anythign in there to ark out agains. What can i do to see if it is not an injector fault as per this post
http://www.skylinesaustralia.com/forums/in...=129897&hl=
Also is there anyway i can tell if it is just an individual coil doing it.
The thing is if it is an injector or something, would gapping the plugs down fix this?
OK So first thing
The BK plugs are essentially the same as the BC plugs just a touch shorter.
so what are all the EYA things for, i know 6 is heat range and so forth, but the rest. DO you think it is benificial to get the BCPR6E or stick with mine and go down to 0.7mm gap
How can i gignose a faulty CAS?
How do i dignose if an injector is faulty?
Other then that, the car is sooo much better, pulls nice, smooth idle, me like.
thanks budy, much appriciated.
I have gone through the maintnace manual and am going to perform all the test to see what i come up with, susspition is down to CAS or injector, or bad earth. LOL, there is a lot of OR's
Maybe you have a hairline crack in the ceramic of one of the plugs?
I done this once when I used a swivel to replace the plug under the cross over pipe. I had the plugs in and out 3-4 times and only saw the crack on the last. Drove me insane trying to track down the slight miss around 5500rpm that would then clear up and pull well to 7000rpm.
So check them all very carefully. :)
Gap to 0.8mm and then try to get to the bottom of what the 'real' cause of your misfire is.
The boost levels your running you should be able to run a 0.8 gap.
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
    • Car looks clean as. You ended up getting quite a bit done 😂  So what's the plan for the exhaust?
    • The only Neo rods that were any different to any other RB25 rods were the DET ones, and they were the same as RB26. Here is a Neo DET rod. O5U part number visible. Here is a post in a thread here on SAU with evidence from someone who has done this before. There are photos in the thread of normal RB25 rods.
    • Sure, but why assume that will be the case forever? And why assume you'll be able to do an oil change to swap back to a stock drain bolt before that happens? And does it even matter when I change the oil at fairly short intervals? Life can be funny sometimes and unexpected things can happen. Like breaking a collarbone so you can't do any work on your car for a few months but the oil change is due so you have to take it to somewhere and hope they don't do something stupid like stacking the new drain plug washer on top of the old one.
    • Do u know how to identify the rods are rb25 or neo ones? Can u look into the pics and tell me is they de or de neo ones. Its confusing becoz my motor has de neo head but block is 25de 75t, so really confusing me about rods, crank.
