My car is currently sitting in my garage for almost 2 weeks after i had a bad experience with a local bodykit workshop in sunshine.. not to mention any names.
Since then the owner of this particular workshop didnt hesitate to have my car back to take off the bodykit he put on and refund me my money.
Now im in need of a Panel beater/aero workshop who would fit spray & fit my new bodykit that i ordered from PSI PARTS.
Does anybody know or recommend any Panel beaters/Aero workshops In Vic pref western suburbs to take on this job i have for them asap.. Consists of trust rear bar, do-luck skirts, eyelids, whole boot and drift lip
Im on holidays until the end on Jan, but doing my own head in as i cant go nowhere to enjoy my lovely time off work.
cheers in advance
Edited by SLYNE
https://www.sau.com.au/forums/topic/151273-panel-beatersaero-workshops/
JAC Smash Repairs. In North Sunshine/Braybrook. He's doing my R33 at the moment. Having fibreglass bonnet/front bar fitted, R33 GTR guards, headlights and painting whole front. You can go have a look, but I just brought it there and not sure if he has started yet.
J.A.C. Smash Repairs
Flag no.2
3 Mullenger St Braybrook VIC 3019
ph: (03) 9364 7544
what car is yours mate?
im looking to get a minor repair job done thru them and i was down there yesterday arvo to get a quote. is yours the white r33 i saw parked in the side street? no grill and gtr wing?
Mines a white 33 no rear bar, no skirts and no spoiler.
you spot it?
down the end of king st, towards north melbourne / dryburgh st
front left bar corner respary (car park scrape)
rear right wheel arch pushed in (car park scrape)
door handle touch up (paint coming off)
$800 total
nah man i only saw one 33 at vu's. was white but i cant really remember the details as i was in a hurry. i kinda remember seeing p plates but not sure.
man i hope just car give the job to dt panels, ive heard a lot of good things about them and their work looks really good. theres a thread over on ns.com with pics if you want. do a search
i put the globes in, they look good.. nice and clear
Haha getting my car washed today [at] wash n shop highpoint
My mates there will polish it and what not and then i'll post some pics up
All i need now is a set of rims to finish off the outside of the car
$800 total
got my car back on friday, very happy, all the bad stuff fixed and the car is spotless now
car looks pefect and very shiny, for the agree'd $800 amount i asked for;
i got for the same price;
full front bar respray
rear right wheel arch pull out and spray
full car detail and polish
wheel clean and shine up
car vacuum and smelly stuff inside
in all a perfect job and they even sprayed the whole front bar at no extra cost.
the workshop is pretty big and they are usually working on 15+ cars at any one time.
it was done @ flagstaff repairs on king st, towards north melbourne, 2 minute drive from flinders st.
dropped car off tuesday morning, picked up friday afternoon so no complaints.
  • 4 weeks later...
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
