just put my engine back in for the 2nd time as i had an issue with the valves,(dont ask)
put it all back in this week, just needed oil and a spark plug as my mate dropped it,
started putting coolant in and opened the bleeder up, blah blah blah, noticed a big puddle of coolant on top of inlet port 1, thought it wass the orings so i put some new ones in, tried it again......
turns out that the brand new tomei metal inlet gaskets i put in 5/6 are good but the 1 inbetween the head and the inlet is leaking, GRRRRRRRRRR.
not keen on pulling the motor out again just to do that,
Have any of you Guys used metal gaskets on teh inlet?
Did you use sealant as well?
Jeremy
https://www.sau.com.au/forums/topic/151284-not-happy-jan/
Oh the wonderfull world of fixing the bloody skyline. Good luck with it. I've got a coolant leak in a bitch of a spot. Starter motor has to come out to get to it.
yeah i know, theyre nothing but.. got it going yesterday arvo, no leaks or anything, but got a tappet noise at cylinder 6, which is where repco machine shop put in my new valves, not happy because the clearances havent been set right, i hate engine noises, makes you look bad when your driving,
done about 18ks now,
make sure you dont lie underneath the starter motor when you unbolt it, cause the coolant puddles on it and then when it moves it goes all over you(as i found out yesterday) lol
https://www.sau.com.au/forums/topic/151284-not-happy-jan/#findComment-2820749
'make sure you dont lie underneath the starter motor when you unbolt it, cause the coolant puddles on it and then when it moves it goes all over you(as i found out yesterday) lol'
Thanks for the warning. That's what it's doing!
https://www.sau.com.au/forums/topic/151284-not-happy-jan/#findComment-2820852
as with all metal gaskets you should use a hylomar spray on them.
and 3 bond around the coolant areas.
thanks Dave, i learnt that one the hard way,
All good now, changed the plugs as 4 were cracked, going great again, but with slight tappet noise from cyl 6
https://www.sau.com.au/forums/topic/151284-not-happy-jan/#findComment-2821200
    • Not stock. All remade. Mostly looks stock because the pipes run to and from the standard holes in the inner guard to get to the return flow FMIC. I'm not sure which question you're trying to ask, because it seems like "stock position" vs "stock position".
    • Hey, it's a GT-R, it's just as significant a moment as mine😁 It's not ideal when things are uncertain; I'm the type of person that always has a set plan for things in life so being unsure of this plan puts me in a weird place mentally.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card style AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had no flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
