Hi i have a rb30e engine i have been working on it has an xf throttle, stainless intake'3"' +pod, cam, ported and plained head, mapassi regulator, rb25de pistons, racing rings,bocsh 450hp fuel pump,stainless extrctors, stainless exhaust with hi flow cat.
This engine will be pushing a fully worked 3 speed trimatic(manual valve body, shift kit and transbrake $3200 !!!!!)
I need a better ecu to push the higger pulse injectors and possibly an extra injector plus the ability to tune more accuratly. What mangement system would best suit this application?Due to not running boost i hope to get away wit alot cheaper then a turbo ecu.
If you know of anyother n/a mods please let me know.
Thank you for replys>[/size][/size]
https://www.sau.com.au/forums/topic/151286-what-ecu-do-i-need/
how can you have RB25 pistons in an RB30 RB25 ones are smaller arent they? or do you have an RB25 block with an RB30 head?
as for the ecu a G-reddy E-manage would be more than adiquit i would think they are about $500 for the old model and $900 for the ultimate model
the rb25 bore is the same its the different stroke that makes it .5 l less (crank and rods)
    • Might be tricky matching the seat trim material  If your got the funds you "may" want to get the rear re-trimed as well to match the front
    • How much is it to re-uploster?  Well that's a "how longs a piece of string?" question !  And I answer thusly: "twice half its length! " . . . . . .  Seriously you'll have to chase multiple quotes for that one from different uphlostrerereres !  Ask around, in your area and on the forums, chase reviews and most of all see the finished product in person cause photoshop is a wonderful thing !
    • Hey everyone!!  I've noticed that whenever I do my oil changes, after putting 4L in, the oil level sits at the top mark in the dipstick. This is after letting the old oil drain for a very long time too! I've checked the oil level daily for the past few mornings. It happens every time and it's confusing because all the threads say that it should take about 4.7L (With some just adding the full 5L) My next thought is to figure out if the dipstick I have is correct so could someone please tell me the length of the RB25DET engine oil dipstick?  I've checked images of some of the genuine dipsticks, but none of them have the length in it. https://justjap.com/products/genuine-nissan-engine-oil-level-dipstick-fits-nissan-r34-skyline-c34-stagea-c35-laurel-y34-cedric-gloria-rb25de-t-neo?currency=AUD&srsltid=AfmBOortQXofgmiHVRKuIaiKuygL4k0Ewp68c3isGZk0vvKOJ7Yqf3iB However.... the engraving on the genuine ones say 05002 while mine says AA000. This makes me believe that maybe I have a wrong dipstick? I just want to confirm before I buy a new one. The car is a fresh import from Japan so I don't have details of the previous owner to ask him. Thanks in advance 🙏🏾
    • Sport. I didn’t rebleed it cause I just removed the slave and left connected.    I will change line and slave and see how it goes.
    • Oh and how is the rattle when foot is on the clutch ?
