For sale: 1991 180sx, with s13 front
Asking Price: $7,500 ono
Killometer's: 135.000
Manual or Automatic transmission: Manual
Engine Type: CA18DET
Modifications: stock turbo, Intercooler, blitz Turbo Timer, 3 inch exhaust from dump, bosch 040 fuel pump, drift pod filter, exedy HD button clutch kit, koyo 53mm radiator, dr-drift re chiped comp, split dump pipe, splitfire coilpacks, z32 air flow meter, vtx front,rear and side skirts, bride brix driver seat, s13 front end, sports s/wheel with quick release, water temp & boost gauge, 17''8 front 17''9 back g-max rims in white, braided brake lines front and rear, HSD hr coilovers, Slotted rotors, solid rear cradle bushes, whiteline strut braces front & back, whiteline sway bars front & back, z32 front brakes.
will throw in: 6 17'' rims ,4 with tyres and 2 without, 5 point roll cage, tein tie rods (brand new still in box), tein castor rods, top stage bonnet vent, stock air box, and what ever else that i can find
Complianced: Yes
Road Worth Certificate: no
Registration: Yes 26/10/2007
Other Comment's about the vehicle: done the sil80 converstion in oct, then primed it in undercoat, just never got around to finshing it. would make a great drifter, most of the work is done, just needs a good lsd, bigger turbo and injectors
reason for selling: need money to pay off loans
Contact luke on - 0409569450 or send me a e-mail at [email protected]
post-8952-1168514750.jpgclicky for more pics
https://www.sau.com.au/forums/topic/151304-sil80/
now sorry if you've already covered this info up there but....
does the car run normally? does it need any work to get it on the road? what is needed for rwc? and it needs a paintjob yeah? ;)
thanks
it runs fine:),it will be sad when it goes, i was setting it up for a track car for a bit of fun, but now i just want to pay some bills, all it needs for some great power is gtr injectors and turbo
for rwc it needs a new seat belt, horn hooked backed up,rassed up a little and maybe a stock afm to hook up the stock air box again, and yeah coat of paint
https://www.sau.com.au/forums/topic/151304-sil80/#findComment-2815655
hmmm ok so would you say it's worth to get say if i wanna use it as a daily driver? coz that's what i'm after
thanks
yeah thats cool, i had it for a daily driver for a while, now since if got another car i dont need it anymore, its sitting here doing nothing
https://www.sau.com.au/forums/topic/151304-sil80/#findComment-2815792
    • Let's hope that's not a copy pump either. There were so many copies of them back in the day.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
