  RCHOO said:
Ok cool. I will keep my eye out for it..
You would catch me having coffee at Chit Chats on the weekends in High st
My Grey R33 would be parked right out the front...
is that the one a few doors up from the lights at the bottom on the shell side? (cant remember the name). my nan used 2 live out in berwick
  • Replies 362
  khunjeng said:
I was thinking the same thing...damn excellent.
Do u just fit them out there, I assume the f/glass moulds are made somewheer else? dunno.
I have driven past a few times...wondered how cool it would be.
I think its just near Protech Autocare on Borina rd...Greg is a ace detailer - plug for them...
We design and manufacture every thing we do. Heres me when i built my boat. Were located in Vinter ave Croydon Vic.
ooo so you'd be a gun fibreglasser ;)
3rd year med. future neurosurgeon right here.........hahahaahaaha i crack myself up. more like i'll probably end up as some research monkey working my ass off for the government the rest of my life.
Edited by Basti
bloody hell....smart ass punk ;)
completed my computer science degree
completed my accounting degree
now looking for a job in accounting/finance
(need it heaps, as my car is due for another mod)
    • Hi, is the HKS  Tower Bar still available ? negotiable ? 馃
