Whats Your Occupation
MELANIE
  • Replies 362
believe it or not i work in aged care! haha im a client services officer for an in home support service that mainly focuses on aged care. i don't do the field work though. best part is im in the relief team so i get a higher pay rate and so far have the training and experience in IT, rostering and admin, billings, debt collection, payroll and OH&S ;)
Geomaticist :dry: (bach of Geomatics)
currently working as a Mathematical Software Architect / Developer in Southbank :) rather cooshy 9-5
also can be called a Spatial Information Scientist,registered Surveyor, Photogrammetrist.
pretty cool profession and jobs are amazingly easy to find. they practically throw them at you.
also a Musician (yep guitarist, hence the Stagea ;) good luck fitting a stack in a skyline)
did alot of touring with previous band around Australia... currently working on a new band :P
Graphic Designer, about a 2 minute drive from my house, but still too far to walk. Even better, I dont have to rock up till 9:30... Could say I'm not going anywhere for a while...
What he said. Except I start at 8:30. 6 Years later, I'm still stuck in the same shitty job. It's boring as hell but I get the run of the place because my boss isn't here half of the time.
I'm planning to quit next year and start my own business.
i work @ coles =/
trying to find a new job at the moment
qualified audio engineer but hey no one needs them =/
want to get into the auto business, heard the pay isnt good but doesnt bother me :banana:
    • Hi everyone, I bought the Redline diff oil and the seller has sent me Redline 75W90NS even though that’s not what’s pictured.  I’ve already booked a hoist to go and change my diff tomorrow but I’m not sure if the NS is ok for the rear diff in a R34 GTT I think the NS does not have any slip modifiers so would that be an issue?    thanks in advance
    • Not easy to find pics from 15 years ago, but here is a partial one. Keep in mind that it curved immediately from the airbox, then kept a straight line for the MAF to read correctly, followed by a 45 degree bend straight down to the turbo. This connection was the most difficult as it had to twist as well as bend to meet the almost vertical straight section of the intake.
    • Yes, well, wrt a wheel alignment, there are two types. Either: You have very little added adjustables, in which case the alignment can be done by anyone in any tyre shop or equivalent, and will only take 30 minutes, and so there is no reason to even consider leaving the car there. OR: The alignment is a major exercise because you have adjustables everywhere and so you will need to be taking it to a shop that is skilled and experienced at setting up race cars and the like, and you won't need to worry about leaving the car there.
    • does anyone know the specs of the R35 master cylinder, rear ratio and knee point? the BM57 is a 0.4 rear ratio with a 435psi knee. I'm looking for someone with a much lower knee pressure. the piston area of the R35 brakes isnt that big so might not work for me but this is interesting.. the other option for me is a GU patrol master cylinder and booster and do the prop valve externally.
    • It sounds like by avoiding maintenance you may be doing more damage than a hypothetical guy in a workshop taking it for a spin. Not sure if you are just being paranoid or things are actually that bad in the US. Find a reputable shop not run by dickheads. Look for people that take pride in their work. Stick around for the day if you have to
