  • Replies 56
swop u my hsv clubsport
FOR SALE
1996 series 2 hsv clubsport /
5 speed hsv racing manul with upgraded rings seals ols clutch fly wheel the works over $3000 spent
air bag
RWK.dyno 230
air con
LSD DIFF custom diff twin spinner cost $2900
bucketseats front and back no rips stains ect
full body kit hsv series 2
hsv mags/new tyers $700
remote central locking
JVC mp3/cd player $300
sub/amp tweters speacer $2000
tint
lowerd
gto sloted roters $680
upgraded break system
hsv imoberliser
paint hsv silver
hsv 185i V8 5L worked upgraed seals oils pistons gasgets the works.over $4000 spent
full rebuild at 140.000km like new car 184.000km on clock now
racing shocks/springs/ $$1500
dule hsv exsorst system $1000
hsv cooling system
custom exstractors hsv $1200
manny more fetuers
custom hsv eco chip good on fule for v8
computer upgraded by hsv poer chiped ect
p plate legel car
mech sound car
RWC.REGO. neg depening on offer/deal
HAS TO GO
very big dollers spent
no rust sevsed every 5000km. 3 owners since new some recpts provided
yes i understand that, but it shits me wen people offer rediculous amounts, for a car with over 20k worth of mods.. somepeople offer wat a stock one goes for!!!!
anyways. have a few people interested, but no confirmations at this stage!!
thanks mate... 20k is a fairly good price i think, its pretty much ready to go and reliable. plus the 12 months rego :(
Edited by mass_iv
Mass has taken me for a ride in this absolute machine. It feels so damn good, especially when on boost. And keeps his car as clean as a girl would ;)
It will be a shame to see this thing go Mass!
GL with the sale - extremely good value for money......... wish this was around when I bought my car last year.. could of saved myself a bundle on all the mods I have bought!
thanks... it has cost me a fair bit... and who ever ends up buying it, will not be disappointed
car now has no stripes, all removed will update pics later tonight or tomoro
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
