hey mate, i recently got a z tune vent moulded into my 32gtr bonnet i noticed around 15+ degree drop in engine temp.
and rain gets in. but i dont really notice it bieng dirty or anything. just made sure the seal around my cam covers and coils is in good form!
just adding to the thread after reading the rest of it.. i have been pulled over by police on a number of occasions and nothing ever mentioned about the bonnet, or headlight.. or anything for that matter.
oh and id like to say that is the best cai i have ever seen. love it.
  • Replies 68
It's to allow hot air out, that's why it is positioned above the turbos; that's also why i like the bonnet i posted.
Hot air rises :)
Ahhh, makes sense :laugh: How much of an effect on cooling would u think it has tho, i mean that vent is pretty small probably not even palm size. I have to admit it looks pretty nice tho, clean and subtle. Cops wont even give it a 2nd glance.
Has someone got some pics of a raised bonnet?
It doesnt look that bad, but its still noticeable. Just imagine ur normal bonnet raised maybe an inch at the part nearer to the windscreen. It sorta looks like some dodgy panel work has been done. Haha their everywhere around here in Malaysia, seems to be pretty common unlike in melb.
Something like this would be good I reckon.
http://www.j-spec.com.au/list/index.php?ID=9223
The one vented bonnet I do like is the do-luck one. It has those fins that arent too large and over the top but still looks like it would do a proper job cooling. Ive never actually seen one of those do-luck bonnets on a real car before tho :P
edit: actually I don't think they're naca ducts now I look at it, looks more like their designed to use the flow of air above the bonnet to pull hot air through it.
the vspec r34 bonnet duct is a NACA duct.
http://en.wikipedia.org/wiki/NACA_duct
  • 3 months later...
I'm looking at a naca duct.
I have not been able to find a good one yet..
The R34 GTR V-Spec 11 and Nur edition have one in the bonnet..
That is what I'm after.
No bling.. just function.
Porsche 924 have them, lotus, some farrari's.. gt40 even the old forb XA GT had them..
but I still have not found a good one!
Anybody got one?
Please PM me!
Cheers.
Aaron
You can buy a bonnet with a naca duct already installed in it from japan, like a one piece thing. I almost purchased one but then i figured its too much to pay for such a small vent? Im not even sure if it'll work well at reducing underbonnet temps. So in the end i got a shift sports bonnet, with the large centre drop vent behind the radiator which will most probably do its job at cooling. I also got a matching vent cover in case it rains/hails whatever heh :sorcerer:
Edited by Yawn
anyone know how rain would affect ur engine...ie rust easier/quicker?.....water falls into ur engine and blows ur cylinders?
say u get a z tune bonnet for u car and u park it outside everyday and it pours wat r u gonna do?
or say u goto work and u have to park outside for 8 hours and it rains for those whole 8 hours?
how will this affect ur car?
ON A TT SUPRA we did some testing at wakefield with streemers on the front bar and on the tip of the bonnet. and on the straight the ones on the grill and upper of the intercooler they were pointing forwards lol. the only thing pulling the air thru the radiator was the engine fan.
thisa was with a louverd bonnet. and a standard bonnet. and no bonnet. all made no differance to watertemp. the only thing that worked was having the intercooler cut in half so the radiatio gets its own air. and a curver partition seperating the rear of the cooler fronm the radiator area. with the cooler venting thru naca ducts on the bar.
also lifting the bonnet is a good trick. but the air doesnt go out of it. but back into the bay and pulls the air under the car.
im gonna try the same idea on my car at our next test day. cos ive got the same issue. at high speed it just gets hot. im no aero dynamacist but im learning
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
