I have the traling edge of my bonnet raised. to be honest I have NFI how much affect it has. the bottome of the windscreen is a fairly low pressure area so it would probably not be drawing that much air though, but giving the air travelling into the engine bay a place to escpape is a good thing. plus when shit goes wrong I will know straight away as oil/coolant/bits fly onto my windcreen!
I've never had a problem with the law, but I do get countless people asking me why my bonnet doesn't shut properly, or telling me I've forogotten to shut my bonnet. one day someone will ask me about it and I will loose the plot and snap them in half. so possible jail time is something to consider before doing it. I don't think it looks bad though.
  • Replies 68
  • 7 months later...
ON A TT SUPRA we did some testing at wakefield with streemers on the front bar and on the tip of the bonnet. and on the straight the ones on the grill and upper of the intercooler they were pointing forwards lol. the only thing pulling the air thru the radiator was the engine fan.
thisa was with a louverd bonnet. and a standard bonnet. and no bonnet. all made no differance to watertemp. the only thing that worked was having the intercooler cut in half so the radiatio gets its own air. and a curver partition seperating the rear of the cooler fronm the radiator area. with the cooler venting thru naca ducts on the bar.
also lifting the bonnet is a good trick. but the air doesnt go out of it. but back into the bay and pulls the air under the car.
im gonna try the same idea on my car at our next test day. cos ive got the same issue. at high speed it just gets hot. im no aero dynamacist but im learning
Did you ever get to do this on your skyline?
Just curious, because i'd like to get hot air out of my engine bay too, and wondered what affect it had on the aero.
can't beat the look of naca ducts but they are designed to force air in and will increase under bonnet pressure. this means that unless there is a good path for air to evacuate from the engine bay - under the car - the pressure will reduce the amount of flow through at the front.
one reason that temps go down with a bonnet vent is that the pressure in the bay is lower and there's more flow through the rad.
i reckon the 32 GTR bonnet with naca ducts would work well - the vaccum created at the rear of the bonnet with the seal gone would pull air through the ducts and decrease the pressure in the bay. anyway it's all conjecture until you get a pressure gauge and a thermometer.
if anyone finds some nice looking naca ducts yell out.
Edited by Scooby
Ive got an East Bear FRP bonnet on my r32 gtst (with the gtr grille). I bought it because it was the only one i found that was subdued (sp?) and didnt look like that fast and furious shit. Its also extremely functional; when the car is stationary, you can feel the hot air being forced out the vent by the clutch fan. Ive not got twin thermos and its even better with them.
The only negative is that it doesnt fit as well as id hoped (im extremely fastideous though), and the cost. It cost me $1700 unpainted, and im still trying to justify that!
Overall though im pretty happy with it. Got it from that place on Silverwater Road in Sydney (i forget the name).
Edited by Shaun
Oh, i forgot to mention that my bonnet comes with a plug type thing that fits on the inside of the vent when its raining. The cost that i mentioned included the bonnet, gtr bonnet latch and the gtr grill.
Shaun.
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
