  • Replies 46
Hmm , so looks like R32GTST's get the 15/16 bore master cylinder .
Some more possibilities , these Nissans have 25.4mm (1") master cylinders .
Maxima 5/90 on 3L , Pathfinder D21 VG30E 4x4 10/92 - 11/95 , Pathfinder R50 V6 4x4 11/95-00 .
Patrol Y60 (GQ series) had both the 1" and 1 1/16 BMC .
Going to have to look through wreckers or pester some poor parts person .
Cheers A .
I had a dig through Pick and Pay Less today and mainly found out what doesn't have what I need . Just about all the larger heavier cars like 280ZX's , Z31 300Z , 300C's use some form of BM44 15/16 bore master cylinders .
The only useful thing I did find was a D21 Navara (5/87) with a Nabco BM50 1" cylinder , perfect except it had no proportioning valve . It also only had 1 front and 1 rear hydraulic line outlet so would need a "T" for the front and some kind of external rear line pressure limiting valve ie like JDM R30's and Bluebirds had .
They had no Y60 (GQ) Patrols or later D50 Pathfinders to look at .
Cheers A .
Interesting....this means you have a good chance finding something local. PBR make local master cylinders for early D21s. Not sure where the lines come out though?
The kindest thing anyone ever did to an Australian built Nissan was to throw all PBR/Girlock hydraulics as far away as possible . Irks me to say it but local content brake components are rubish compared to JDM bits .
Rally fraternity hate PBR/Girlock cylinders because they are built to a price not to a standard .
Thanks anyway cheers A .
  • 1 month later...
discopotato03, I'd like to wade in on this discussion. I'm currently looking for a solution for my S13 Silvia I'm building that now has a set of R33 GT-R Brembo's fitted:
Pics
http://www.sillbeer.com/2007/01/and-now-wh...ew-hotness.html
Now I also saw the article on the US site where they had used a Z32 300ZX Brembo brake upgrade and went for the 1 1/16" non-ABS BMC. Unfortunately like you I've realised they're only in LHD guise (UGH!!!!).
So if anyone can help in identifying if Nissan (ie. Nabco/Tokico) make a 1 1/16" non-ABS BMC for RHD situations from a car with a similar weight distribution as a Skyline/Silvia, please speak up...otherwise a 1" might have to do. Part numbers would be very helpful too.
Cheers
Brendan
Just a thought, but according to most specifications around the web, the R32 GT-R N1 versions had the ABS removed to reduce weight, would that then point towards the possibility of them having a 3 port brake master cylinder in the larger BM57 size?
Anyone?
Edited by VSPEC32
Dayam aye, why is the R33 one smaller? You'd think less travel, more force would be better (except when you lock them up too easily)
Just remember to think about the correct meaning of the words you are using....and never forget these two equations.
Pressure (P) = Force (F) / Area (A) .................... Eqn (1)
Friction = uN (Normal force N) .................... Eqn (2)
A few things impact on the general setup...but we can neglect pedal ratio as we are using all this different gear on the same car (Assumed).
So you put a smaller master cylinder in your car. That means you have less area of piston. So making the denominator smaller does not affect the numerator. So that is using a smaller master cylinder doesnt directly affect the force...it affects the pressure. It increases the pressure in the brake lines.
Now that is related to the caliper and pistons/pads as its the pressure in the brake lines that apply a normal force to the pad onto the rotor.
So there are two types of friction, static and kinetec. Now whilst static friciton is higher then kinetic, we dont want to be locking brakes. As that means we have less grip with the road as a locked tyre is modelled as kinetic friction. (remember thats the lower of friction values...bad if we are tryign to stop a car) So remember a rolling tyres grip level is modelled by static friction, ie no relative slip between the two surfaces.
So not wanting to lock a tyre, we must ensure the pad is moving relative to the rotor. ie Kinetic friction.
Now we only want enough force that brings the pad and rotors to the brink of lock up. If we lock up we lose tyre grip with the road.
So remembering that P = F/A. You havent changed your calipers, so the Area of pitons is the same. Having increase the pressure in the lines means that F=PA. A is constant, so the more pressure we have the more force we have.
So that all said, this all assumes the same pedal effort all the way back at Eqn 1. So you apply a 10kg load onto the brake pedal with a smaller master cylinder you will be closer to locking up the brakes with a smaller master cylinder then you would a larger master cylinder. If you have bigger pistons in your caliper and combine that with a smaller master cylinder then you will again have brakes that lock up too easily.
So if you increase the piston size in your calipers, then its not a bad idea to increase the diameter in your BMC. It helps not to have a hair trigger brake pad ready to lock your rotor as soon as you look at the brake pedal. Looking at Nissan it seems they have done the same thing.
Now take this with a grain of salt, but i have driven an R32 GTSt with Brembos it stopped realy nicely. Loved how it stopped. I have driven an R33 GTSt with Brembos and i jumped on the pedal and instantly locked them all up and crashed into witches hats. Now i dont know what pads and tyres were like, and the R33 was on a slippery skid pan...but its something that is in the back of my mind.
So why did Nissan drop the BMC size on the R33. I dont know. But if ppl can tell me the coeffecient of friciton of the R32 and R33 std pads...i suspect they dropped the BMC size as they reduced the friction in the pad used as the car had bigger rotors and would handle the heat better then an R32. Lower temp pads normally means lower friction coeffecient.
The GTRs which would have had more performance orientated pads woudl have had a higher u level meaning that a pedal offering more modulation / travel would be desirable.
Has anyone got any solid information on this?
Our Targa car is a genuine R33 N1, it has ABS. I'm pretty sure i've heard duncan taling about the R32 N1 ATTESSA unit, as it's ABS functions are deleted, so R32 N1 (and Nismo) have no ABS.
Better late than never.
Late 1992 R32 GTST Non-ABS Master Cyl.
Excellent pedal feel. Almost too easy to lock all 4 wheels but that comes down to the pad that I run.
Hasn't had a flush for 1yr. :S
Only markings I can see on it are:
BM-44
NAB00
I had a mate with a Late 1992 GTS4 check his he said it says..
Japan Nissan Tokico BM50
Just had a look at mine
car was originally an 1993 R32 GTS and it has a Tokico BM38.
pedal feel is good with the crappy single piston callipers but i am going to have to upgrade it now that gtr32 calipers and 324mm rotors are going on or I am guessing the pedal would hit the floor before lockup :glare:
OK, still trying to track down information on the brake master cylinder from an R32 GT-R N1 (BNR32 N1) - I did manage to find a Chassis number...would that help anyone in tracking it down?
R32 GT-R V-SPEC N1 > KBNR32RBFS ZN
R32 GT-R V-SPEC II N1 > KBNR32RBFS8 ZN
Cheers
Brendan
Edited by VSPEC32
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
