Hi guys,
Those running ATMO BOV's will know the problem of stalling between gear changes.
Now the APEXI SAFC 1,2 and neo should all be tuned by a professional on the dyno for best SAFE results.
You can however tune the 'dec air' function of ur safc with no problem following this guide outlined below.
I have done htis to my r33 and have great results.
DEC AIR SETTINGS
""when the car is completely cool start it up. have the safc mointoring throttle %, air flow, and rpms. have the engine at 1000rpms and write down the air flow. then have the engine at 2000rpms and write down the throttle % and air flow.
now go to the dec. air settings. the THR setting is the throttle % you documented at 2000rpms. the NE1 setting is the air flow you had at 1000rpms. the NE2 setting is the air flow you had at 2000rpms. this will get you very close to the settings you need. may not be perfect but very close. this will allow you to run an atmospheric bov without stumbling between gears""
One thing i do different- I set my Thr% to 1%. this basically tells the safc that when there is less than 1% of throttle to use the 'dec air' settings i have outlined, have had no issues with this so far.
This will not effect the rest of ur drving or ecu maps, only the off throttle so u car wont stall any more.
Side note- The SAFC is a useful interceptor piggy back computer. However If tuned incorrectly with out proper tools or knowhow can casue major damage to your engine.
I have Used this method for DEC AIR wiht great results.
Edited by tmc_2
https://www.sau.com.au/forums/topic/151358-safc-dec-air-tuning/
Can this also be done on a PFC?
Hi Kennedy,
From what i know the PFC controls this as good as or better than the SAFC.
I dont know how to tune one or what its called on a PFC as i have not yet had the opportunity to use one.
I would think a PFC would have a much more wholesome method of controlling 'dec air' settings as well as other engine conditions.
If your having trouble with that metal intake pipe causeing stalling maybe try getting ur pfc tuned and emphasise to the tuner why.
I had constant stalling issues after installing the metal intake pipe. I installed it corectly and have no leaks.
With my SAFC NEO tuned using this above method and stopped it stalling completley.
Let me know how things go.
Hi Kennedy,
The car has been tuned and I asked hitman if he could "tune" it out but he said he cant.
Bearing in mind that my car only has hunt issues if I dont make boost. eg...when putting around a car park and stuff. If I'm giving it then slow down and shift down/slip into nuetral then the car idle drops brack straight to 800rpm and stays there. It only happens when RPM doesnt exceed around 2K RPM
Hmm must be something to do with how ur intake return pipes are. I don thave any hunting issues now i have secured a decent BOV return and iol breather return.
Id say thats wherer the problem lies.
  • 2 years later...
  • 3 months later...
bump,
can this be used to elimitate the plumback function altogether? upgraded to a bigger turbo and didnt think about the plumback :) , so car stalling all the time.
yes, this is for if you have an aftermarket blowoff valve that vents the excess air out instead of the stock bypass valve returning the unused air into the system.
it would help with the stalling but what also helps is bumping your idle up alittle.
nothing will be perfect for cars that are not meant to vent to atmo, only cars that run on a map sensor instead of a maf like us will not stall.
what are you using for a blowoff valve?
    • Update: Tunehouse looked into the problem and identified a wiring issue between the camera unit and the connector. They managed to get it working , but did warn me at some point it will stop working again. From their perspective it is unserviceable and will need replacement. They did some research and found that the new replacement camera would be Approx $1400 supply only (their fitting cost would be $190) . They did provide the part number (28442-JL05B) and a quick google of the part number shows that these are rather expensive brand new (seemingly no longer in manufacture) for the places that still have them in stock, with the used option potentially presenting  the same issue down the track at some unknown point. They are happy for me to supply the part so that they can fit it. Decisions, decisions... I can definitely recommend Tunehouse (thankyou Vee37!). Cost for the diagnosis was as quoted  ($190) , car was ready on time and communication was top notch. Their workshop is super clean and modern, and there was plenty of car candy parked out the front on the day I went.   Would definitely go back.
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
