I had the squealing noise at start up occasionally and read the thread on fixing it.
Unfortunately I can't see any of the photos attached in the thread, but there appears to be a missing nut on the adjustor bracket on my carpost-33161-1168559832.jpg. Where the long adjustor bolt threads into the block, poking out the front is a bolt that looks like it needs a nut (see attached photo). Nissan couldn't tell me whether a nut is meant to go there or not
There definately isn't a nut needed. I think your bolt is through the wrong way to be honest, the block is threaded from memory and the bolt when tightened should lock the assembly in place against the bracket. As it is now it can potentially flap about.
The pic is not very clear so i cant tell if you have the bolt that holds the block on . As BHdave said the block is threded and is bolted on the alternator with another bolt M8 from memory, you undo this a little then turn the long ajusting bolt until you have the correct tension and tighten the other bolt .
Agreed agreed.
The long bolt does not need a nut. It is locked into place by another bolt that runs perpendicular to the one pictured. Undo that locking bolt first, then the long one in the picture will turn without much resistance.
Oh I see what people are saying about the bolt being backwards. I think they're referring to the locking bolt. You can see the end of it poking out the front. I guess now this is the one you were talking about? It's threaded in that block where the head of the bolt is. (towards the rear)
I can't remember which way round it is supposed to be, but if it's backwards, then it won't be doing any locking whatsoever. I'll check mine next time I go downstairs for a smoko.
On every RB I've ever worked on that block is not threaded other than for the long adjustor bolt, but is clearance drilled and it's actually the mating lug on the alternator that is threaded (ie the part where you can see the bolt sticking out toward the bottom of that photo). So the lock bolt (which is what it's for - securing the adjuster mechanism) passes through that block, then the long adjuster bracket - which has a long, slotted hole - and finally screws into the threaded lug on the alternator. The idea is that the bolt clamps the block and the alternator to the adjustment bracket, which itself is attached to the block at the waterpump.
Looking at that photo I suspect your problem could be that the bolt is too long. The standard bolt would only stick out from the alternator lug by a few mm at most. It's not standard and it's possible that there isn't enough thread, which means the bolt isn't able to be tightened sufficiently before running out of thread. This would mean that it would _appear_ that the bolt was tight when it actually wasn't and that might explain your squeels. Either that or some idiot has stripped the thread in the alternator lug and slipped in a longer bolt to fix the problem, in which case there should also be a nut on that bolt (and the fact that there isn't one would also explain the squeels, etc).
There you go! The bolt is in the correct way. And as SteveL said, I can also see that my locking bolt doesn't stick out anywhere near that far.
Edited by RANDY
    • me too wasnt real happy and cost me a penny or 2 to replace
    • But there's the archetype for the name plate! Here's my view on that stupid TÜV ruleset. Buy a brand name aftermarket piece of equipment. In this case, the Mines front pipe we're talking about. Get it TÜV certified on the car. Damage the underside of it, say on a speed bump. Cut out the damaged section, replace with fresh metal. (For the sake of the argument only), continue doing that to the whole pipe until it is all gone, replaced with new metal. Is this grandfather's axe still the same front pipe? The design hasn't changed (much). The pipe walls are in the same places. The flanges are in the same places. It is functionally identical. How does this differ from a pipe that is ever so slightly different in fabrication (ie the number of welds in it, a few mm here and there in terms of where the pipes run, are joined, etc)? Anyone with 0.5% of a brain can see that there is absolutely no way that the performance (power, environmental aspects, noise, etc etc) of it can be any different than the genuine Mines pipe. Maybe even Mines made 2 versions of this design, with the same differences. How would anyone (say a TÜV inspector) ever be able to differentiate between them? And yet, they are so bloody anally retentive about this stuff. Mad. How upset would they be if you had the wrong spring washers on the flanges?
    • Sakura (cherry blossom) tree at the end of a path going through Kabutoyama Park in Nishinomiya, Japan. Taken with Sharp Aquos R8
    • After a fairly extensive search using Japanese terms and checking Minkara etc, I couldn't find anything even close to your front pipe in the photos. I'm no expert but the two pipes merge really close to the flange connected to the catalytic converter which is rather unique from what I've seen, which makes me think it's more than likely a custom front pipe. The welds and 'more pipe sections than usual for a brand name pipe' makes it seem like a custom one.  Here's some photos of an old Mine's front pipe. You can see that it's just 4 pipe sections as opposed to 6, and arguably looks more like a 'production' front pipe:
    • Wtb r33 low side s2 ac line
