What's that weird motor noise I get with my portable CD player?
[JSC]
Many people report problems while playing CDs from a portable CD player
into their car audio systems. The problem, stated very simply, has to
do with the stepping of the motor requiring a varying amount of current
and non-isolated power and audio signal grounds. Using a liberal
application of capacitors and inductors, this voltage variance can be
restricted to a window of 8.990 to 9.005V for a 9V CD player, yet even
the swing between these two levels is enough to cause annoyingly loud
noise on the outputs. It has been reported that this entire problem
can be solved by using a true DC-DC inverter at the power input to the
CD player.
So the stepping in the motor that pushes the laser around or the motor that varies the spin speed of the disc draws various amounts of current.
My motor or alternator whine noise happens when I listen to the radio too.
I also beleive this only happens to people who run RCA cables to an amp? That's when mine did it, anyway.
Edited by RANDY
Tried that too. Tried running the RCA's completely out of the car, then into the boot. No change.
Earthing the RCA's helped about 50% at the time. You just run a wire from the outer contact to somewhere metal on the car. It got rid of the noise quite a bit, but it was still there.
The noise apparently comes in when either the HU or the amp isn't grounding the negative part of the RCA cable properly. These cables carry 2v or more in them, so plugging them in and out while everything is powered up can kill the grounding fuse or track in either your HU, amp, or both!
I opened my HU when I had this problem, and found the ground track was burnt through. I bridged it with some wire, tested with a multimeter and put it back in. No change at all. I suspect it's blown somewhere else too.
I've also got this problem & part of my trouble I believe is the stupid installers set the amp up with the rear speaker RCA connections to the amp jammed under the fuel pump relay. I have to rotate my amp the other way around, this will probably cure half my problem. But they also have not grounded the RCA's at the amp, so they had NFI (COMPLETE AUDIO U SUCK!)
grounding is always the problem here. it is caused from the wrong resistance termination on a end of line. for example i have no issues running cd or radio tuner. however i have a AUX which goes to a stereo lead so i can plug in ipods, phones etc to listen to music. because this line doesnt have a EOL resistance on it it humms with the alternator due to incorrect ground loop. easiest way to fix is u can get filters from a audio shop which u put at the speaker to filter out noise on ur grounding wire. just cut ur negative wire at the speaker and put it in just before the speaker. a capacitor would probably work as well assuming its big enough and doesnt explode. safer to get a proper kit from somewhere like jaycar.
Installing filter caps on the speaker wires is an absolute last resort as this will also affect the sounds of the audio, & not really a solution to a problem that shouldn't be there. If your problem is on the input to the head unit then that's where it has to be fixed. You may need to change your lead set up on your auxillary to cure you're issues.
The problem with my set up, is that the RCA cables have got a ground wire that's meant to be connected at the head unit & the amp & it hasn't been done, so the input to the amp is effectively floating, doesn't have the same ground reference as the head unit & therefore highly susceptable to interfearance. Getting it away from the bloody fuel pump relay will also help in my case.
Edited by JazzaR33
    • I think the consensus was that's normal. Sloped road surfaces or something? I remember @silviaz went through this before. It might be one of those things you never notice until you pay attention to it.
    • Im not entirely sure exactly what or where its leaking from, he started to pull the boots to swap to my new tie rods + ends and it just vomited fluid, so he closed em up up, swapped the rod ends to the old rods and let me know so I can figure a solution out, im guessing its all origional as as I passed 103k miles earlier this year im sure its just in need of a full overhual/rebuild anyways.    If i could just yank it off and be good it wouldn't be an issue to ship it out and wait for the turnaround but the guy I work with doesnt really have space to keep my car for a week or two at a time, would rather drop it off and have a replacement ready to drop in
    • What do you mean by "seals"? Internal hydraulic seals (ie, is it leaking PS fluid?) or the rack boots that close the rack onto the tie-rods? Because the former is a rebuild, and the latter is trivial that you or any nearby mechanic could do. Dunno about the cowl. Just buy what you think is required and get anything else you find/break afterwards. Wing? Dunno. Don't like R33s enough to pay attention to them. Mirror glass is just glass (on the surface that you want to polish). Go for it.
    • Hello! Long time lurker, been using the forums to address concerns and questions from afar for a while but I've struggled to find some answers so I guess its about time I made an account and formally asked some more knowledgeable people, since finding local skyline owners is hard (and shops that are knowledgeable or trustworthy to work on 'rare' cars are non existent out where im at, as skylines are quite uncommon to find in the wild around here). So the main 3 questions I have, 1: Steering rack has blown seals, well.. they kind of hold but they are not sealed properly anymore and as my R33 is my DD, i cant exactly rip the rack out and send it off or attempt to fix myself. As most refurb ones are around $1,100 or more shipped, and I have other things I need to work on around the car, I was seeking clarification on whether an S15 rack will more or less bolt right in, and whether a common mechanic could do any other required work to get it to fit. I ask, as I've found a supplier than can sell a manufactured as oem one for around 400, if not I'll likely order a used one from Jacks JDM, and take a risk on the seals there. The second question i have is that im replacing the front wiper cowl and have planned to buy 4 new clips and a new center clip but wasnt sure if there were any other clips that would also need to get replaced while I was at it. Given im sure any that are there now will simply break when I remove the old cowl... Last thing would be a fairly straight forward question, i think. If I manage (strong if, finding one has proven to be a pain) to find a R33 GTR spoiler/wing will it require much modification to bolt to a S2 R33 GTST? I've read the bolt patterns dont match but otherwise would bolt in, only options I have found with much luck is China stuff on ebay and carbonetics, which has a nice $650 shipping fee... so if anyone has any pointers where a US chap could locate one that would be great Random side question as well, the mirrors as I understand are mirror glass, and as im planning to polish my windows from water spots and surface scratches, i was hopeful cerium oxide would be fine for them too, as my research points to, but clarification is always nice. Any pointers would be appreciated, and while I have scoured the internet for answers if I missed a prior post somewhere that may answer these directly please point me towards it, as i must have simply missed it. I have seen a post here or there that has mentioned it, but I usually get 50-50 answers, or half answers... I dont have a lot of fab experience or mechanic experience, outside of hydraulic and pneumatic stuff I did in the military and with how hard it is to source stuff in the US, id rather not wing it and hemmoraghe money lol. Thanks guys! Sorry for the monumental first post haha
    • Yep, there's a very minor drift left that happens a few seconds after letting go of the steering wheel, but not enough to bother me. Enjoying the car still!
