hey gang we are now selling our unreg'd R30
she needs a new windscreen, battery clamp and a few small things like kick panels being put back in..
just wondering if theres any interest in a old skyline..i gotta ask $500 for her the cash is going onto a deposit for another car pics of the R30 are further doing on the posts
pm me here
[email protected] if u wanna talk on msn
or my number is 0405102405
Edited by ratz26
https://www.sau.com.au/forums/topic/151414-sold/
hey gang we maybe selling our unreg'd R30
just wondering if theres any interest in a old skyline..and what price i should expect to sell her for
GET SOME PICS UP....Pics can make the sale.
i bought mine for $400, mint condition. (except steering & brakes)
normally a few hundred, but not much more.
is it auto or manual?
good tyres?
last rego?
km of engine?
colour?
sedan or hatch?
S or Ti
what year?
And i am interested by the way.... need spares!
https://www.sau.com.au/forums/topic/151414-sold/#findComment-2817362
its a 5sp manual
shes done 322*** k's
dunno about the rego i got her unreg'd
shes grey in colour
its a sedan
shes not turbo'd
and shes a oct 93 build
Edited by ratz26
https://www.sau.com.au/forums/topic/151414-sold/#findComment-2817387
how much work do you think is needed tio get it back on the road?
(love the look of the chrome rings)
those km are impressive! just goes to show how long these last!
lastly where are you located??
Just looking at the wheels its not a Ti, no power windows!
https://www.sau.com.au/forums/topic/151414-sold/#findComment-2818081
sorry mag i wont be parting her out IF i do sell her it will be as a whole car..
sorry it took so long to reply im a rural firefighter and we've been real busy thanks to f**kwits lighting fires
https://www.sau.com.au/forums/topic/151414-sold/#findComment-2822981
i got 2 ti rims with black inside and chrome ring for $20+ postage which prob isnt worth it
but my engine did 370xxx and was still going fine not to sure about tranny but they are damn strong engines
oh yeah ratz26 i paid $1000 for mine and it needed heaps of shit done to it alot more then yours would need but although yours isnt a ti i'd say try for around $700 or something like that
Edited by paulmac
https://www.sau.com.au/forums/topic/151414-sold/#findComment-2824504
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
