HI
Anyone with a S2 R33 and splitfires, WITH A MULTIMETER, got to their splitfire coils and do a resistance reading between the ground, center plug and the LH one when looking at the coil, for the coil. ALSO tell me what the mulitmeter was set at? i have 20, 200, 2000, 20k, 200k, and 2000k ohms.
I tested mine and i get 1600ohms, when the mulitmeter is set to 2000ohm reading. The AUTO electritian told me it has to be 0.9 ohms, and that is near imposible.
This is to do with my other thread, i can't seam to fix my car. http://www.skylinesaustralia.com/forums/in...howtopic=151261
Because you have a series 2, the coils on your car differ greatly from an older car's coil. Yours has the transistor drive built into the coil package, whereas the earlier engines had a seperate transistor pack.
On the older, seperate transistor, coil engines the reading on the primary side should be about 0.9Ω.
On your car you are trying to read through the transistor as well as the coil winding, so your reading will be a lot different.
Use your diode test on your meter, and go between pins 1 and 2, both ways round. Compare the reading you get with the other 5 coils. See wether there is a variation between the set.
Hope that helps at all.
James.
Edited by heller44
  • 1 year later...
Sorry to dig up an old thread like this but i am also keen on knowing this!
I have a similar problem. I just want to know whether the reading should be between .6-.9ohms.. can anyone confirm??
    • Yes to both! Yes to standard ECU and tune, but exhaust is aftermarket. Unsure on brand. Actually have it sitting in at my desk haha! I have to set it up on my laptop but this is a great next step, will do. So I generally try to shift before 4.5K RPM most times. I largely don't do a lot of high-rev driving, but I will take it up to red 1-2x a week max, as I know the occasional "Italian tune-up" is good for these cars.  Oh wow, is this way better than what I'm getting. Does this mean there's a good chance I have an issue?   Thanks for all the info so far guys.
    • Old Son, did you re-use the Holden ABS in the new shell or try a different module?
    • Yeah, nah. I had the actuator rod off it today. The arm will not move at all. Neither out, nor in. Yeah, you'd think so, but I've been thinking about that. Even when the actuator rod fell all the way off at the beginning of this saga, it would build more boost and faster in lower gears than it would in higher gears, and you'd think that that was the opposite of what should happen. But I strongly suspect that there is a thing with the gearing getting the revs to rise faster, that there must be some transient effect with the gas flow rate rising quickly, that you don't get with the more steady state case of the higher gears. Keep in mind - the gate is not shut in either of my weirdnesses. So things are not "normal". We normally think about a turbo spooling up (below the wastegate target) with the gate shut. I have all sorts of mental models running now where the gate is a little bit open, and having it stuck open allowing gas out while it should be going through the turbine has all sorts of weird effects (in these mental models). I'm thinking in the higher gears, the ex mani pressure builds to the point where enough gases spill out the wastegate to just prevent the pressure rising much more at all, or just creeping up, all the whole the revs are increasing and getting closer to the point where a gear shift becomes necessary.
    • Is it possibly wastegate actuator itself is sticking, or even the rod to flapper? Otherwise I reckon things are getting a bit rusty/worn   Also odd it won't boost in 3rd to 5th, but will in 1st, I'd expect the other way around with it slightly open as there's more time on your way to redline for it to spin up
    • Does anyone know ow what these two plugs are for and if they should be unplugged? Just put the dash back together and can't remember if these were plugged in before or unplugged! (Blue and white plugs) 🤦🏽‍♂️
