I've been told it will make a MASSIVE difference, and am about to sound-deaden my doors and install new splits. Have also seen some sort of sound-deadening sheeting, looks like a foam, which i think is meant to go behind the speaker.
https://www.sau.com.au/forums/topic/151480-sound-deadening/#findComment-2818594
I believe you are referring to a diffuser mat.
aah00n if you want your car to sound good, get the deadening. Doesn't even have to be the whole door - I only had the forward half of my doors deadened and it made a significant improvement.
https://www.sau.com.au/forums/topic/151480-sound-deadening/#findComment-2818603
now I've started something :laugh:
it makes a huge difference. camera isnt here but I'll show you a 33 door (beofre and after) when I find my camera.
the whole idea is to make the door as acoustically dead as possible (there is a LOT of tech to this but that is the gist of it,.) so you have almost zero refelctions and cancelation.
the foam stops the reflections the sound deadening stops the panels from moving by adding weight. the result is better sound and a quieter car when the music is off.
https://www.sau.com.au/forums/topic/151480-sound-deadening/#findComment-2818607
Dont forget to add, that deadening the inner skin, separates the back speaker movement sound waves from the front there fore eliminating mid cancellation, and improving midbass ten fold :laugh:.
The Dynaxorb diffuser mats have specific ridges which disperse the backwaves and stop them from bouncing back onto the speaker cone, therefore improving power handling and less distortion.
George
Adelaide Pro Sound
Edited by Adelaideprosound
https://www.sau.com.au/forums/topic/151480-sound-deadening/#findComment-2819070
  • 7 months later...
Old post, see if someone notices it...
If I get my doors deadened, and the diffuser mat placed in, then change my door speakers later does the diffuser mat have to removed/reglued etc?
Does it connect to the speaker, or just go straight onto the door, moulded to the speaker depth etc?
Thanks...
https://www.sau.com.au/forums/topic/151480-sound-deadening/#findComment-3292466
yeah man as above fully worth it
Get some dynamat extreme or b-quiet
then put a layer behind where the speaker sits, then rip off the factory plastic, get all th sticky stuff off with meths
then cover the whole door, all the wholes, cut out the part where the speaker will go(cut it in triangles from the inside of the circle, so not just cutting round it, so make about 10 cuts from the centre to the outer diameter of the speaker
You'll be left with triangle strips, leave those in, put the speaker in and you'll really really notice the different :(
I'll try get pics too
https://www.sau.com.au/forums/topic/151480-sound-deadening/#findComment-3292721
Here are some pics of mine. I used mostly Bostik, but will be striping this back and using all Dynamat Extreme in the near future. SDing your ride will make a significant difference, I did the boot when it was striped out and it made a huge difference to quietening the exhaust.
And this is the FG weather/water shield I made to protect the speaker. It's covered in DME.
So you can see the inner and outer skins are done, I went so far as to wrap the side intrusion beams! The bostik is very easy to work with, you just heat up the panels (they are 500mmx500mm) and the become soft and easy to mould to panels. Similar to DM, you just peel backing of to expose a sticky side.
Hope this helps, and sorry about the phone pics, I didn't have a digi cam when I did the SDing.
Edited by rocketboy
https://www.sau.com.au/forums/topic/151480-sound-deadening/#findComment-3295017
Just did my parcel shelf today with Dynamat, all the rattles and squeaks are gone :laugh:, One wedge pack managed to do most of it, i didnt cover every single part of the shelf, but will when i get some more Dynamat. There was some left over but im about to tackle my front doors, so i dont want to run out and the odd shapes might come in handy. Should of taken a pic, will post it up when i move my splits to the rear and put my new ones in the front.
cheers
Evil
https://www.sau.com.au/forums/topic/151480-sound-deadening/#findComment-3297199
I did my doors a while ago now and it is great. It dropped out a fair bit of cabin noise and I have only done the doors. I probably went a little overboard but oh well. I want to do pieces of my rear parcel shelf and a bit on the inside of some of the flatter panels of the car at the rear.
Pics of what I did with my doors
https://www.sau.com.au/forums/topic/151480-sound-deadening/#findComment-3299347
I've had it all done too. Acess holes filled in with aluminium sheet, then that covered with dynamat. Those pads behind the speakers. Then the foam on the door cards as well to stop them rattleing, and to kill a bit more noise.
To say the least it made a HUGE difference. Mid bass was increased, road noise was reduced. The doors now also make that nice thud noise when they close. Which is just a perk I guess.
https://www.sau.com.au/forums/topic/151480-sound-deadening/#findComment-3316911
    • Certainly. It is probably broken under the wire style clamp. At least that one is easier to get at than the front one.   Sounds like it isn't a major leak, I'd start with backing off the the water feed and return banjos into the turbos half a turn then tightening properly. Hardlines can still crack over time, either in the tube (particularly when turbos are changed if the banjo is siezed in the the tube) or at the brazed joins between the lines and the banjo fittings. A coolant system pressure test will reveal all. BTW you'd be able to get a sump without exchange, it will just cost more as they will have to source another stock one for the next customer. If you want to address the sump a much better option is something like this https://www.hioctanedirect.com/hi-octane-racing-sump-extension-nissan-rb26 that you weld in locally (and add the oil return fittings at the same time)
    • Pretty sure you are thinking of the throwout bearing there (which you should change when you change your clutch), when they are worn they will get quieter if you put your foot on the clutch. An input shaft bearing is turning/noisy at all times.
    • I’ll have more of a look into Recaros over the weekend. It’s taken me 2 days to figure out which Bride seats suit my application haha.
    • I am aware of their presence, but the product page looked like that conversion will eliminate the AWD capability. Fact remains it's kind of a hassle to send my oil sump halfway around the world and buying an extra one is expensive and unnecessary. Before I go hat route I'd explore more local options.    Would you recommend I just pull the engine and renew as many things as possible since I'm already having problems with some leaks? Would have to get an engine crane first though.
    • Are there any indicators that the vehicle is in limp mode?  Any dash light, or something.  Or is it just lack of acceleration?
