Can Somone Help Me, Got Splitfires And Still Nothing
SO this is where i am up to now.
MUST READ THIS FIRST
http://www.skylinesaustralia.com/forums/in...151261&st=0
I have checked a few things and going to do alot more checking arround. BUT i got new splitfire coils, from SLIDE, and put them in and the car still misfires. I have the stock ECU with an SAFC II tuned by kutz, and all seams ok, but i still have to run .6mm gap so that it doesn't missfire, now that sux.
Can somone help me, where can i get my splitfires checked out to see if they are ok, and what else should i do?
Hay toffy, i did the folowing last night.
CAS out and tested, correct opperation and correct voltages.
Pulled out the coil loom, correct voltages, and no bad earths, all trigers correct. Coils gettign 12.4V and triger 10.2V.
All injectors correct, work as per manual, triger correctly.
Now back to 0.6mm gap and see how that goes.
I am so fed up, this sux. Sorry all sprakplugs are new too.
How did you check the injectors cobber???
I know that when my car started to miss cause of a fuel misshap when i pulled them out and got them check that 2 were knackered when they looked ok!!!
Have you check each coil indiviually to see if it just a dodgy one???
Honestly it doesn't sound like it was the stock coils giving you grief to begin with!!!
Well i haven't pulled the injectors out, just did the test in the book, voltages, resistance, and pulsed each individially, the thing is each plug looks exactly thesame, no leaning out or nothing. There are no leaks of any sought. The thing is too, it would be missfirying at the TOP aswell but it does not.
Well i am oly doing what seamed logical, i mean the coils were definatly shot, the old spark looked like something geriatric.
The car performance is definatly better, easier starts, better idle, and fuel consumption is up aswell.
I don't have the money to do much more right now, but i might have to look into the injectors.
BUT talking to KUTSI it definatly spark related as it happens at the peak cylinder pressure. So who knows. i think it's electrical, in regards to spark.
It certainly sounds electrical cobber.
You changed your ECU didn't you, do you still have the other one to try and see if that makes a difference at all???
My 33 had been playing up for a while backfireing and the engine cutting out. Thought it was to CAS but changed that and it was still doing the same thing. I finally found out the the plug that joined Haltech to the factory loom was a little loose and the connection would cut out and kill the engine.
Just something else to check.
After all that. I'd replae the old wiring loom (ignighter module to coil packs), with new fresh wires, of a larger size(there can be a performance gain as well). I'd replace your ingiter module, permanently. Then index your plugs, for height and point the gap (in the plug) at the intake valves (just mark a line on the ceramic with a texta....
Well i will check the connection plugs, but all seam preatty good, will do.
In regards to ignitor, i have a S2, and do not have it, it's inbuilt to the coils.
Does anyone have a S2 loom i can borrow overnight to have a look, i did check mine and it seamed ok, no lose conections or anyting, all good earths.
CAN YOU tell me what the plug indexing is, i think i understand, you mean point the electrode tip towards the intake valve, correct? How do you know if it is going to be the correct way in the head? ALSO what do you mean index for height?, ensure that all the plugs are the same spark gap, or hight of electrode?
SO DOES anyone have a loom i can borrow?
    • Hello everyone, I'm glad to join you.
    • Definitely do-able haha. I will give it a try if the fuel pump hanger does not solve the issue. Just need to find some quiet time in the area, Malta is like a big city and I live right next to the main hospital so it is very busy during the day. I'll be installing it in about 2 weeks, found a garage that is pretty knowledgeable and has the necessary tools. This garage has worked on multiple builds, even for competitions. They even asked me to stay with, so I should be fine.
    • Just to add, I found the r32 gtr ecu the most forgiving, the r33 one would get the shits.
    • For what it’s worth I drove my gtr for over a decade with gt-ss as a true daily after I pulled off the -5s, I had it engineered and went with stock ecu etc.  never skipped a beat.    I would only worry if you can’t get good fuel all the time in a tropical paradise
    • I bought an engine from a friend of a friend many years ago, it was sold to me as a RB25det Neo.    recently I started pulling it apart and noticed that the intake manifold was pretty different from others that I had seen on RB engines so did a bit of research and found that it was a non turbo manifold. So I’m sceptical now that it is a NEO DET and just thinking it’s a NEO DE (it does have a turbo strapped to it currently).    can you identify the engine model from the numbers on the block?
