Can Somone Help Me, Got Splitfires And Still Nothing
SO this is where i am up to now.
MUST READ THIS FIRST
http://www.skylinesaustralia.com/forums/in...151261&st=0
I have checked a few things and going to do alot more checking arround. BUT i got new splitfire coils, from SLIDE, and put them in and the car still misfires. I have the stock ECU with an SAFC II tuned by kutz, and all seams ok, but i still have to run .6mm gap so that it doesn't missfire, now that sux.
Can somone help me, where can i get my splitfires checked out to see if they are ok, and what else should i do?
Hay toffy, i did the folowing last night.
CAS out and tested, correct opperation and correct voltages.
Pulled out the coil loom, correct voltages, and no bad earths, all trigers correct. Coils gettign 12.4V and triger 10.2V.
All injectors correct, work as per manual, triger correctly.
Now back to 0.6mm gap and see how that goes.
I am so fed up, this sux. Sorry all sprakplugs are new too.
How did you check the injectors cobber???
I know that when my car started to miss cause of a fuel misshap when i pulled them out and got them check that 2 were knackered when they looked ok!!!
Have you check each coil indiviually to see if it just a dodgy one???
Honestly it doesn't sound like it was the stock coils giving you grief to begin with!!!
Well i haven't pulled the injectors out, just did the test in the book, voltages, resistance, and pulsed each individially, the thing is each plug looks exactly thesame, no leaning out or nothing. There are no leaks of any sought. The thing is too, it would be missfirying at the TOP aswell but it does not.
Well i am oly doing what seamed logical, i mean the coils were definatly shot, the old spark looked like something geriatric.
The car performance is definatly better, easier starts, better idle, and fuel consumption is up aswell.
I don't have the money to do much more right now, but i might have to look into the injectors.
BUT talking to KUTSI it definatly spark related as it happens at the peak cylinder pressure. So who knows. i think it's electrical, in regards to spark.
It certainly sounds electrical cobber.
You changed your ECU didn't you, do you still have the other one to try and see if that makes a difference at all???
My 33 had been playing up for a while backfireing and the engine cutting out. Thought it was to CAS but changed that and it was still doing the same thing. I finally found out the the plug that joined Haltech to the factory loom was a little loose and the connection would cut out and kill the engine.
Just something else to check.
After all that. I'd replae the old wiring loom (ignighter module to coil packs), with new fresh wires, of a larger size(there can be a performance gain as well). I'd replace your ingiter module, permanently. Then index your plugs, for height and point the gap (in the plug) at the intake valves (just mark a line on the ceramic with a texta....
Well i will check the connection plugs, but all seam preatty good, will do.
In regards to ignitor, i have a S2, and do not have it, it's inbuilt to the coils.
Does anyone have a S2 loom i can borrow overnight to have a look, i did check mine and it seamed ok, no lose conections or anyting, all good earths.
CAN YOU tell me what the plug indexing is, i think i understand, you mean point the electrode tip towards the intake valve, correct? How do you know if it is going to be the correct way in the head? ALSO what do you mean index for height?, ensure that all the plugs are the same spark gap, or hight of electrode?
SO DOES anyone have a loom i can borrow?
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
