Sound quality is HEAPS better with splits Correct.
How much are you looking to spend, do you want some advice on quality brands ? What price are you looking to spend?
Where are you located so we can recomend some good dealers to go to.
George
Righto George, I am keen for some decent advice on the speakers. I have all of the other components for the system and now I need to match some decent speakers so I can get it all installed in one go.
Here is what I have so far:
- Kicker KX200.2 Amp (for the sub)
- Kenwood 200W RMS 12" sub
- JVC KW-AVX700 head unit (http://www.jvc-australia.com/JVC/client/c_...&prodID=173)
As far as speakers go the guys on the forum have convinced me to go with 6.5" for the front and back.
I don't really want to spend more than $200 on a set of front splits and the backs don't need to be anything too flash. The speakers will be running off the head unit so I need to find speakers that are going to match the HU right?
My original plan was to go with a set of Alpine SPE-17CS ($138) 35W RMS splits for the front and a cheaper set of Alpines for the back. I am not too sure of the output quality of the HU (20W RMS?? is what I was told) and have been told that the above Alpines will certainly match it well. This is my main concern as I don't want to waste money on better speakers unless the HU is gunna have the power to drive them.
Anyway guys, give me your advice on the above. Would you go with the Alpines? What others would you suggest? Don't want to spend more than $300 all up for front and backs.
BTW George, I am in Nth Ryde. Always happy to purchase via the net or through your recommended dealers. Let me know.
https://www.sau.com.au/forums/topic/151518-splits-or-not/#findComment-2820263
I put kenwood dual mag? splits in rear of mine and they sound good. Also put 5x7 pioneer 2 ways in the front doors. with 10 inch sub sounds great with not too much weight, I guess it's getting late, I don't think this ryme an't great.
https://www.sau.com.au/forums/topic/151518-splits-or-not/#findComment-2820564
can vouch on that one.sounds real crisp...
https://www.sau.com.au/forums/topic/151518-splits-or-not/#findComment-2820919
righto now i am confused... i thought i was making the right decision by using splits in the front and some 2 ways in the back... these last few posts are contradicting that completely... AAHHH WHAT TO DO.....
Personally i've liked components in the front and the rear (tried it a couple of times) and to me it just sounds that the are fighting each other with the top end (my personal opinion) and they synch just didn't seem the same.
Personally i always go a good set of splits in the front with 2ways in the rear (normally i dont worry about rears anymore) and i've been playing around with different sub applications (at the moment trying to perfect a dual bazooka tube) and i only run a 4channel amp now.
This is mainly to cut costs and the fact that i spend money on the go before the show now and im not really fazed with the boom boom anymore, just like to have a nice crisp sound while im at the track :huh:
Speak to some of the pro guys on here like Chris & George as im sure they will be able to give you alot better idea of audio set up and get the best sound from what you already have :(
Good luck with it what ever way you go.
GMB
https://www.sau.com.au/forums/topic/151518-splits-or-not/#findComment-2820920
OK guys. Going to get new speakers today for my r32. Question is should I get splits 6's for the front or just go with some 2 way coax?
Is the sound quality heaps better with the splits or not?
yes.
If ur on a tight budget, forget the rear fill's, spend the money u save there on a good set of front splits, amp them if u can for good mids n highs. Ur already running a sub thru an amp so thats the lows taken care of.
Dont forget sound deadening, well worth it if u can afford it. If ur on a tight budget, just sound deaden as much of the doors as u can afford, then move on to the boot if ur budget allows.
https://www.sau.com.au/forums/topic/151518-splits-or-not/#findComment-2822343
Might be better to pick your splits first - there are so many different sounding ones you can get, warm sounding ones (for vocals), harser sounding ones which might be better for loud dance, etc etc etc. Go and listen to some, find a pair that suits the music you normally listen to, then get the right amp to drive them.
https://www.sau.com.au/forums/topic/151518-splits-or-not/#findComment-2832469
Just don't bother with rears. Combine the price you wanted to spend on them and just get fronts.
Check out the lower end of the Boston Acoustic gear.
Agree.
I've got a pair of JL splits at the front and replaced the rear speakers with some xplods that are a few years old.
https://www.sau.com.au/forums/topic/151518-splits-or-not/#findComment-2837837
OK i have narrowed it down. I am after a set of splits that will match the Kicker IX404. I am considering SoundStream XSC.6 6.5" and want to know if you guys think it is worth spending a bit extra and getting the Tarantula TRC.6N 6.5"?
Will there be a noticeable difference in the two?
Also, what would you guys recommend... the SoundStreams or a set of Kicker K6.2 splits?
https://www.sau.com.au/forums/topic/151518-splits-or-not/#findComment-2838569
Im running some cadence 6.5inch splits in the front, cadence 6 inch 2-ways in rear and a 12inch sub in the boot and i get some sweet sound out of that, in my opinion go for the splits i really noticed the difference when i got mine.
https://www.sau.com.au/forums/topic/151518-splits-or-not/#findComment-2838786
neither. Kicker and Soundstream r more better for amps and subs. For front splits brand to look out for r Hertz, Boston, Focal, DD, Morel, Rainbow, Dynaudio, etc. Last 3 r quite expensive. All these brands, except last 3, have something for each price range. There all good just depends which u think r better, which can only be done by listening to them. Some might have harsh tweeters, lack of midbass compared to others, etc
Also the best cheap splits r the Jaycar 6.5" Kelvar Splits that can be had for $150 :)
You can get these from:
www.fhrxstudios.com/
Doran Pro Audio
https://www.sau.com.au/forums/topic/151518-splits-or-not/#findComment-2844197
    • I have engineer in my job title One of or motto's though is "we make and we break"
    • This is actually 2 whole different trains of thought that need to be addressed separately. No, as Matt says above, "Engineer" is not a directly protected title. A lot of guys who just do mechanical design via CAD, with or without even some sort of associate diploma in engineering, often have the job title of "Design Engineer". A train driver can probably still describe themselves as an engineer. But, to usefully get employment with anyone as a proper engineer, you're going to have to have at least the necessary and relevant degree qualification. You're not going to get a job as an electrical engineer if you have a chem eng degree, unless you can demonstrate x number of years of working in that capacity, sufficient knowledge, etc. Having the degree is at least in indication that you've seen the relevant text books, even if you haven't read them (like pretty much the last 10 years of graduates!). To be a self employed engineer.....you could get away with quite a lot pretending that you're suitably qualified, without actually being a proper engineer. But, you will find yourself unable to work for a large section of the client space because a lot demand CVs and capability statements when considering contracting for any engineering work these days. Insurances too. If you're not a proper engineer, it will be much harder to obtain proper PI insurance. Insurance companies have gotten hip to that. The "Professional Engineer" thing is a thing in Australia. If you have the right qualifications and experience you can apply to the relevant engineering top level body (mostly Engineers Australia, the less said about whom, the better), to be assessed and approved as a Chartered Professional Engineer, CPE. There are high bars to get over and a requirement for CPD to maintain it. The RPEQ thing is similar-ish, in that you have to demonstrate and maintain, but the bars are a little lower. It is required to be RPEQ in order to sign off as an engineer on any engineering design in Queensland. The other states haven't fully followed suit yet. There's "engineering" and there's "engineering". Being an engineer that signs off on timber (or even steel) frames for housing projects, council creek crossing bridges, etc, is a flavour of civil engineering that barely warrants the name, description and degree. That would be soul crushing work anyway. Being an automotive engineer working in the space where you have to sign off on modifications to cars and trucks would also be similarly soul crushing. At least partly because of the level of clientelle, their expecations, depths of bank balance, etc. And that brings us to your second question. No, we do not have professional engineers "do vehicle inspections". Well, not the regular roadworthies, etc etc. That's done by mechanics. There might be some vehicle standards engineers at the various state govco inspection stations where cars go to get defects cleared and so on, but that's because they (the cars) are there specifically for defect inspection and clearance and so the stakes are a little higher than on an annual lights and brakes working check. But, if you modify a vehicle in Australia, you have to get it engineered. A suitably qualified (and effectively licensed, which I will get back to) automotive engineer will have to go over the application, advise on what would be required to make the mods legal, supervise some parts of the work, inspect and test the results, and sign off. The "licensed" aspect comes from there being a list of approved engineers to do these things in each state. They have to jump through hoops set up by the govco vehicle standards divisions that mean only the suitably qualified can offer to and approve such mods.
    • It's got a problem Prank... It looks like both washer spray caps have fallen off this car... 😛
    • Meh, it's only got to last another 10 years or so until you'll be forbidden to drive it. Keep it dry and forget about it.
    • The title of Engineer is not protected. However different states have different rules about what an Engineer requires to operate. Engineering for a motor vehicle modification is very different to engineering for a bridge, electronics, etc, including what that engineer needs as certifications.   In Canberra, "Engineer" is the loosest category with basically nothing stopping you calling yourself and engineer and designing a bridge or building. From what I've reviewed, QLD has the strictest requirements through RPEIQ.
