I don't go back to school for another 16 days dude.
It's an excuse to sit on SAU all day, not have to go outside and get my precious skin burnt by the harmful sun, and be in contact with the public.
Hahaha :unsure:
1. Do you feel the current P plate restrictions are suitable?
No
2. Would you drive a prohibited vehicle (turbo, v8) if you could?
Yes
3. Do you feel you take more care around P platers on the road?
No
4. Do you like the idea of having a passenger limit for P platers?
No
5. Do you regulary (atleast once everyday) speed (purposely go over speed limit)?
No
7. Do you follow the speed on the freeway and stay within your 90 or 100km/h limit? (If you have one)
Yes
8. Has all the recent articles about P plater deaths made you slow down?
No
9. Do you see more P platers doing the right or wrong thing when you are out driving? (Be honest please)
Right
10. Do you think passenger restrictions will solve the P plate death issue? Or does more need to be done?
No
11. Do you trust getting into a car with a P plater? Or do you trust your child getting into a car with a P plater?
Yes
12. Please tick what licence you are on:
Full Green Ps
13. Are you male or female?
Male
P-Plater Survey
No
I'm off P's
Yes red ones
Yes
Yes but only a couple of km/h
Don't have one
Yes
Right
More
Yes
Full
Male
Thanks guys.
Filled them all out.
Just entering in the numbers now :D (in Excel).
Thank you once again for helping me with this. As it looks there are quite different opinions about the P plate issues, but thanks for all your input.
No more surveys need to be done thank you
  • 2 months later...
Sorry to rebirth an old thread.
Just wanted to thank everyone once again for their help.
I think the result is pretty self-explanatory.
Thanks guys.
I put A LOT of time into this, and thankfully the teacher saw that.
Was pretty funny, the class got a two week extension because no one had "finished" (started lol) when we started this year (when it was due).
Maybe i'm just a nerd? :(
Males: Yes – 8 – No – 12
Females: Yes – 11 – No - 9
Yes
Male Female
10 4
No
Male Female
1 11
I'm off Ps (Doesn't affect me)
Male Female
9 6
Do you feel that you take more care around P platers on the road?
Yes
Male Female
12 10
No
Male Female
8 10
Yes
Male Female
10 5
No
Male Female
10 15
Do you regularly (at least once everyday) speed (purposely go over the limit?)
Yes
Male Female
6 3
No
Male Female
9 8
If I'm in a rush
Male Female
5 9
(If I'm in a rush was a trick :( - Basically saying yes but not wanting to admit it)
Do you follow the speed on the freeway and stay within your 90 or 100km/h limit (if you have one)?
Yes
Male Female
8 7
No
Male Female
5 8
I don't have one
Male Female
7 5
Have all the recent articles about P plater deaths made you slow down?
Yes
Male Female
6 10
No
Male Female
14 10
Right
Male Female
8 10
Wrong
Male Female
12 10
Yes
Male Female
6 2
No
Male Female
7 9
More needs to be done
Male Female
7 9
Yes
Male Female
12 15
No
Male Female
8 5
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
