I was just looking around the on the floor of my R34 and I noticed this little box? Any ideas on what exactly it is?! My research seems to indicate a turbo timer even though this does not work as far as I can tell. Also we got the remote in the last picture with the car and had no idea what it was for (car was straight from Japan). I guess it might be for remote starting of the car?
Also I was sure all R34's came standard with an immobiliser security system but mine doesn't seem to have one, I wonder if it was disabled in order to get the remote starting to work?
I have no idea, will ask some people who can read Japanese properly.
Weird! :wave:
https://www.sau.com.au/forums/topic/151655-starbo/
Damn it - looks like I will need to invest in a proper immobiliser or alarm. I just want the standard factory key with buttons though, I have having the extra button fob things...
I actually got the remote starting to work!!! I just had to flick the 3rd dip switch. Trouble is it keeps running the starter motor. In some of my reading on the unit (theres next to nothing in english on it) it seems there is an option that should fix this so it just gets it started then stops the starter. Will need some jap translated I think.
Will be handy for warming the car up in the morning as I am always late for work and tend to drive it a bit harder than I should when its cold.
https://www.sau.com.au/forums/topic/151655-starbo/#findComment-2821687
a remote car starter is a good way to have premature failure of your starter, Normal cheap arsed systems work off a timing circuit (hence engaged for a while after the car starts). They should also sense when the alternator is running so that they cant re-engage once the car is running.
Unless you want bling, I wouldn't worry about it.
Cheers
Sumo
https://www.sau.com.au/forums/topic/151655-starbo/#findComment-2829039
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
