They dont remove speed limiter, only remove boost cut.
To remove Speedlimiter, Cut wire 53 on the ECU.
What i am going to do is wire in a switch so that if i wanna go fast, i just flick the switch and 200+ is there for me.
Althou Zdenko, there is no way u are goin to his speedlimiter down the 1/4 unless ur car is very modified.
  • Replies 120
I've come up against many a WRX.
All i do is turn my my 'system' to drown out their over-sized exhaust and drop the clutch from about 3.5k-4k/rpm, shift every gear at 7k/rpm and leave MAJORITY of them behind!
Only WRX's that have beaten my so far are STI's and the occational MOD'd WRX.
My car is stock R33GTSt S1, with 3" cat-back exhaust, I don't even bother dragging WRX's in the wet though... AWD vrs stock 205's... i couldn't handle the shame!
lol @ phorj
dont forget in most cases its all in the driver, i mean at calder when i went for the first time i pulled a flat 15 in my car which should be doing low 14s at least but i did beat an sti which was running mid 15s, cearly we are both shit drivers LOL!
hehe.. yer, his run was funny..
13.981 one was my first ever run so i was happy with that.. can only get better.
Cos supposeldy the cutting of wire 53 can cause HICAS to screw up sometimes without reason. Hence having a switch, it wouldnt happen when off.
Not that i've seen and i have no speed limiter.. More likely to be due to dodgy BOSS kit than anything else
lol
hahah nah nah nah...
my take of was sweet..
i dumped da clutch as it was bouncing aroun dlike a bitch.. i managed to pop it into nuteral... and wondering y i was redlining and goin no where
hahaha
things like this happen
thats y it shits me when people say ohh skylines r shit.. my car can run 13s ( a vn supercahrged 6 PFFT please i leave him for dead)
i had guys that say they can do a time but never run it...
annoys the **** out of me,.
Guest
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
