Hi all. I was recently looking at the GCG catalogue and came accross Bell Mouth Inlets for all different sized turbos. I was wondering if they are just for looks or are used for power gain???
Below are example pictures from the GCG site. (www.gcg.com.au)
All replys appreciated...
RoB
https://www.sau.com.au/forums/topic/151672-bell-mouth-inlets/
A bell mouth allows the air to transition smoothly into a runner. If it had square edges a turbulent layer sets up near the walls effectively reducing the size of the runner so the amount of air that can be drawn in reduces. I have conducted multiple experiments in labs to verify the existence of this phenomena.
And it is Waz. Not only does it introduce horrendous turbulence, the bastard can suck closed at higher boost levels.
Nissan did an amazing job of the stock setup for the era, but it falls far short in some areas when the hammer drops.
  • 1 year later...
OK so i understnad that the difference in power would be in proportion to the car, the amount of power the motor is producing and what mods are being used but what sort of power difference are we talking about???
They fitted one of these in one of the High performance Imports DVD's and tested the power gains, if I remember correctly there was a 1-2kw improvement.
I thought they were just a funnel so it can suck more rocks in LOL
Seriously the power increase depends on what you are comparing it to, if you compare it to a high flow with a stock intake there would be gains(as the standard intake sucks closed) However compared to a well setup intake, there is minimal gain.
I should know all about this, I have an exam on it next week :teehee:. What Geoff said is spot on. Bellmouth intakes are generally used because the duct loss is so slight it's considered to be zero, makes it easier to calculate things. I'd be interested to see the cfm output of a turbo compressor at a given rpm with/without a bellmouth intake. Maybe if you went from stock intake piping to bellmouth intake sticking out your bonnet you might notice a difference but otherwise I doubt it.
lets not forget a map sensor for all you Afm boys and girls out there. .....initial cost of the exercise for a 1 or 2 kilowatt gain....it's a little impractical
No, you use it inside a larger pipe or in an airbox. Take a look in the stock ones on a Skyline. Little bellmouths. Also in the HKS pod (which is a piece of junk BTW) there is a nice one with a gradual flare. Made a nice exit from the custom airbox on my race car which has the AFM, twin turbos and high compression 3 litres of goodness. But what would us engineers know hey Kyle. Drifters have invented everything so far, just ask them. Do well on the exams mate.
They don't need to be a full rolled lip either, just a nicely curved entry into the piping.
RoB
The bellmouth assists with the induction of small mammals and young children into the turbine without arms and legs getting caught up on the lip of the compressor housing :rofl:
    • And half of them have been converted to turbos.
    • Welcome. This is not really true. We have a whole forum here just for the NA shitboxen. And they are not very different from the turbo shitboxen. Just weaker brakes and gearboxes, and no LSD, for the most part.
    • I'm pretty sure it has an 040 in it @Duncan Also reading up, that turbo should top out at 250 as you first thought. It will be interesting to see how early it chokes due to the changes in the head too
    • Yeah confirmed they are Nismo 555s, found the boxes in the spares with the factory injectors in. Yeah the AAC has been relocated to allow reuse of the factory brake booster line, and yes confirmed it has a 1 way valve in it. Unfortunately the one on the car is cracked, I'll need to replace it. Pretty sure I've got all the AAC plumbing correct in my previous post, but I am going to source some new fittings with 90o angles to help with the hose routing and also one really specific moulded shape for the AAC intake to cold start hose (will raid the back of our local repco when I get a chance and work out some combo that works) One of the big things I learned in the GTR is you need to be able to get your hands all around the bay when something goes wrong. I've done a bunch of re-routing now and it should be much more practical now. Also got the BOV mount re TIG-ed by the local engineering shop so that should be good to go now. Never got to the fuel pump because of some life stuff today, but will pull it to confirm it is suitable for 300rwkw when I get a chance
    • Hello everyone, I am from Malta and have recently bought myself a fully stock 1992 Nissan Skyline GTS. It has the RB20DE engine and thus is NA. Unfortunately, not a lot of information can be found online related to the GTS, unlike the information for GTS-T and GTR variants. Apart of the Skyline, I also got a 1984 Porsche 924 2.0l NA and a 2002 Renault Clio 1.5DCi for everyday use. Excited to be apart of the community and perhaps get better information on cars such as the GTS.
