Most of the aftermarket gizmos can be interchanged.. EBC's, exhausts, intercoolers, wheels, turbos.. actually thats most things.
U need a different ECU or aftermarket ECU. Depends how specific you're getting.. engine parts is that what you're getting at?
Originally posted by predator666
you can fit any intercooler to anything with the right piping and adjustment..
If you put it that way, then our idea of interchangeable is different. To me, interchangeable means you do not have to alter anything out of one car and fit the part to the other... But for the exhaust system, you'd have to alter a lot of things in order to fit an R33's to an R34 and vice versa. Probably the entire piping.
yeah, i mean interchangeable as in take off and bolt right on. Actually i'm looking at getting suspension from a r33 gtst or r33 gtr. I've been told the r33 gtr and r34 gtt have same suspension setup so this will work, but what about from a r33 gtst to r34 gtt?
thanx shiro for the info on the exhaust.. it's gonna be hard to find a second hand exhaust then.
Nope, certainly not from an R33 GTS-t to an R34 GT-t... Trust me on this one. Yes, it's hard to find a second hand exhaust. But if I am not mistaken, there is one for sale on www.japanesemotorsport.com.au
Check them out, they might be able to help... Or would like to buy mine, instead? Hehehe... I ahve not really decided, though... I might but I am not sure yet at this stage...
fade, this may help you.
I recently measured my stock 34 intercooler and its approximately 225 x 200 x 80 [all in mm]. Thats the core size only, not including end tanks. May help you decide whether its much of an upgrade or not. I have read that the 34 are thicker by 20mm [almost an inch].
Cheers.
    • I mean this in no disrespect to u mate; Are there clear tagged examples/explanations in our SAU forum for example, in my interest, this is how to do R34 Gtt suspension the right way? U guys did so much taking risks with experimentation that deserves recognition and those results helps us morons take the RIGHT path to buy quality / buy once. 🍻
    • Pretty much what you'd expect at that power level. Hypergear turbo, long list of supporting mods, full Haltech catalogue, etc.  I'd say this goes for most drivers, suspension is still a dark art for most people. And it's really hard to convince someone how much better their setup could be...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
