i've got a full house RB26 with
HKS 25/40 turbos,
full decked head intake and exhaust
HKS 700cc injectors
Nismo adjustable fuel reg
Split fire coils
Apexi camshafts 280
Apexi head gasket
SS Valves
Pistons
Rods
Crank
N1 Water + Oil pump
with front LSD
All work was done in japan, egine came across as is with car.. i've spent plenty of $$$ on detailing and extra performance bits
Came from my R32 GTR which was written off, got hit in the back..
Located in Sydney, $25K now $20K or make an offer
0433 384 056 DAYTIME
pics are posted
Edited by WLD_GTR
https://www.sau.com.au/forums/topic/151712-full-house-rb26-turbos/
Mate i understand and thanks for the heads up, But here u get the quality and reliability of full house workshop engine from japan.. also $25k is just a starter i did mention to Make An Offer, but i shall drop the asking price too.. thanks
Sorry i dont noe wat crank, rods, or pistons are in there.. but iam guessing from the apexi head gasket and camshafts that it would be all apexi.. iam not to sure on how much kms since it was built or who built it.. as i previously said that i purchased the car from japan and the motor was already in it. So as i previously said it is a complete built engine from a workshop in japan. You cant go wrong with the quality and reliability from a japanese workshop. Also with the HKS 25/40 turbos already bolted on. No it is not an N1 block
Edited by WLD_GTR
Japanese workshops are just like Aussie ones...there are good and bad...for all you know it could be a STD bottom end with bolt on's done on the grass under a tarp beside his lean-to. Some REAL facts and information about the product your selling would be a good start. 2540 turbo's have been out of production for a few years now and yours look a bit tired. It could have been built more than 5 years ago and possibly has plenty of klms on it. A realistic price would be a good start too....possibly even less than half your current price may find you a buyer.
  • 1 month later...
ill offer u $6000 IF it passes compression? you can keep the turbos...... and ill come pickup today?
That's a great offer. I'd consider taking it if I was you.
My mates R32 GTR made 450 kw at all 4 on the Autosalon dyno with a big single. :rofl: He thought it had a built bottom end even a storker. Some time later the engine spun a bearing from cracking a oil pump.
He was devstated and happy at the same time finally opening his engine and seeing the bottom end was totally standard. But he was happy to have produced 750-800bhp with standard pistons and rods. :)
Just shows what an amazing CRD tune can do :P
    • Let's hope that's not a copy pump either. There were so many copies of them back in the day.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
