I've recently started looking into a car stereo and so far I've pencilled in around $1600 worth of stuff. But they're of mixed manufacturers.
12" pioneer sub
JL splits
Alpine mono block amp
JVC double din screen CD/DVD (WHICH WAS A STEAL for
$650!
Just wondering if having different names would affect anything? I chose these due to prices...
https://www.sau.com.au/forums/topic/151714-mixing-audio-manufacturers/
12" pioneer sub
JL splits
$650!
As long as its all quality stuff I wouldnt be worried, so therfore you should be fine. Where alot of people go wrong is spend big on speakers and subs, then buy a $100 1200w boss audio amp from strathfield and then wonder why it sounds sh1t.
hahah thanks for the piece of mind, I can sleep easy now. All I need to do now is buy it and install them.
Cheers guys!
I agree, from a sound perspective, it makes no difference.
From a resale perspective, if you're planning on keeping the car, depreciation will balance things out.
A single brand "looks" better to the buyer-but if you've got a great price for the gear-enjoy it.
There's no technical reason why consumer gear can't be mixed and matched, provided you follow basic guidelines:
1) any distortion means you're driving some component (head/amp/driver) too hard - back off before you melt something
2) it's a misnomer that a 50W amp can't blow 100W drivers - distortion kills lots of things - refer point 1.
3) based on point 2, it's better to have an amp that's slightly higher power than your speakers, as that way you're likely to be driving clean power up until the clipping point of the speakers (ie your speakers clip before your amps do). Nothing blows a driver like clipping at the driver's limit. Tricky with splits as you don't really know the power split between woofer and tweeter (same issue with coax drivers) - again, if you hear distortion, turn down the volume.
4) for truly staggering sound you can't go past active crossovers - a separate amp per driver, with an electronic crossover splitting the sound at low level feeding each amp. More expensive in amps and a crossover.
Fantastic sound but in my expeience (in home stereos - I haven't gone nuts in my car stereo), drivers (esp tweeters) tend to destroy themselves occasionally (you have a power amp at full gain connected directly to each driver-any glitches get amplified and go through the driver voicecoil).
The reasons for going active are numerous but not necessarily warranted in a car unless you want ultimate sound.
cheers
Mike
    • I think the concept is highlighting the various scenarios where thicker oil helps, and thicker oil potentially doesn't help and only generates heat and costs power, in turn for safety which isn't actually any safer (unless you're going real hot). If anything this does highlight why throwing Castrol 10w-60 for your track days is always a solid, safe bet.
    • Jason should have shown a real viscosity vs temp chart. All the grades have very little viscosity difference at full operating temperature.
    • Oops... I meant to include the connector  view... BR/W - power from fuse L/W - motor negative to fan control amp (and off to HVAC pin19) OR/B - PWM signal (from HVAC pin20) B --  ground
    • Yep, if you are applying filler it sounds like there is something wrong with the body lol. Safe to assume there is going to be a lot of sanding going on if your still applying fillers.  Picture a perfect bare metal panel, smooth as glass. You lay down your primer, it's perfect. (why are you going to sand it?) You lay down the colour and clear, it's perfect. No sanding at all took place and you've got a perfectly finished panel.  You won't be chasing your tail, sounds like you were prepping to start laying filler. If your happy with the body after the sanding, there is some bare metal exposed and some areas with primer, no issues at all, start laying the filler. You are safe to lay filler on bare metal or primer (of course check your technical data sheet as usual for what your filler is happy to adhere to).  This isn't a 100% correct statement. There is primer that is happy to adhere to smooth bare metal. There are fillers that are happy to adhere to smooth bare metal. Just make sure you're using the right materials for the job.  Typically if you are using filler, you would go primer, colour and clear. I've never seen any instances before where someone has laid colour over body filler (maybe this happens, but I haven't seen it before). So your plan sounds pretty normal to me.
    • I don't think there's any way someone is push starting this car.. I honestly can barely move it, and moving it and steering it is just flat out not possible. I'm sure it is, but needs a bigger man than me. I have a refurbished starter now. The starter man was quite clear and consise showing me how nothing inside a starter really should contribute to slow cranking, and turned out that for the most part... my starter was entirely fine. Still, some of the wear items were replaced and luckily it didn't show any signs of getting too hot, being unfit for use, etc. Which is 'good'. I also noticed the starter definitely sounded different, which is a bit odd considering nothing should have really changed there.... Removed and refit, and we'll pretend one of the manifold bolts didn't fully tighten up and is only "pretty" tight. GM only wants 18ft/lb anyway. I also found a way to properly get my analog wideband reading very slightly leaner than the serial wideband. There's Greg related reasons for this. The serial output is the absolute source of truth, but it is a total asshole to actually stay connected and needs a laptop. The analog input does not, and works with standalone datalogging. Previously the analog input read slightly richer, but if I am aiming at 12.7 I do not want one of the widebands to be saying 12.7 when the source of truth is 13.0. Now the source of truth will be 12.65 and the Analog Wideband will read 12.7. So when I tune to 12.7 it'll be ever so slightly safer. While messing with all of this and idling extensively I can confirm my car seems to restart better while hot now. I did add an old Skyline battery cable between the head and the body though, though now I really realise I should have chosen the frame. Maybe that's a future job. The internet would have you believe that this is caused by bad grounds. In finding out where my grounds actually were I found out the engine bay battery post actually goes to the engine, as well as a seperate one (from the post) to the body of the car. So now there's a third one making the Grounding Triangle which is now a thing. I also from extensive idling have this graph. Temperature (°C) Voltage (V) 85 1.59 80 1.74 75 1.94 70 2.1 65 2.33 60 2.56 55 2.78 50 2.98 45 3.23 40 3.51 35 3.75 30 4.00   Plotted it looks like this. Which is actually... pretty linear? I have not actually put the formula into HPTuners. I will have to re-engage brain and/or re-engage the people who wanted more data to magically do it for me. Tune should be good for the 30th!
