Hi,
I have a few items for sale.
1. MV Automatics Manual Valve Body
Item was purchased through MV, installed but the project has been abandonned, its in perfect working order, complete and ready to install. To suit R32, R33, Z32 automatic box's (RE4R01A, RE4R03A)
No pics at this stage (it looks like a regular valve body, the magic is on the inside.)
2. MV Automatics Solonoid Shift Controller
Shift Controller
3. VG30DET T3 BB Turbo
This turbo was taken from a low km VG30DET front cut I purchased. The cut had 40,000 km's (digital dash) and the turbo is really clean.
pic1
pic2
pic3
pic4
pic5
pic6
4. T3 - T25/T28 adapter - less than 40mm thick
I had this made to put a T28 onto my stock FJ20 exhaust manifold, but would suit many many other applications. I had it custom made at Bushell Engineering in brisbane. It sealed perfectly and never gave me any trouble.
At only 40mm thick it will suit alot of cars, other adapters available do the same thing however are ALOT thicker, and not as strong. It will allow you to install a well sized internally gated T2x turbo onto your RB20/25.
pic1
pic2
pic3
pic4
pic5
Prices.
MV Valve Body $250 (was $350 from memory)
MV Solonoid Controller $200 (was $300ish from memory)
VG30 Turbo $400 ono
T3-T28 Adapter $120 ono.
Thanks
I can be contacted via mobile, MSN or email.
ph. 0419 172 032
email : [email protected]
Edited by tim510
https://www.sau.com.au/forums/topic/151715-garage-sale/
just wandering, this is not the shift kit for an auto is it? once this valve body is installed the auto must be shifted manually right?
interested just not clear on whether this is the shift kit or not or is this suitable for a daily driver skyline.
https://www.sau.com.au/forums/topic/151715-garage-sale/#findComment-2826023
oh and is installing like installing a "regualar" valve body?
have a read of this.
http://www.skylinesaustralia.com/forums/in...l=mv+automatics
the valve body allows the stock auto ecu to controll the solonoids, or u can run the lock up box for a more aggressive shift.
have a read of this. this is a for sale thread, not a technical one sorry
Edited by tim510
https://www.sau.com.au/forums/topic/151715-garage-sale/#findComment-2826162
    • If that's the wiring from the factory, I'd be inspecting the loom everywhere.   Any signs of that anywhere else, and seriously, I'd get rid of the car ASAP before the electrical gremlins make it worthless, or it goes up in flames on its own. That is scary how that insulation is failing!
    • I should note too as I have all 4 wheel speed inputs to the emtron I now have the emtron controlling the attessa solenoid for 4wd/traction and launch control strategies.
    • It works quite well with the adjustibility within each of the programs of the turbolamik. Essentially p1 is drive and lockup comes on like a normal driver.  But in program 7 I have customised it to not request the lockup clutch to engage until something like 6500/7 when slip was the lowest.
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
