Hye guys, i just changed my plugs to NGK's, gapped at 0.8.
when i had a major service done, they put in either 1.0 or 1.1.
now, i have noticed that it has a miss at idle, but not high up in the rev range, ie not 4500 and beyond.
now, i will be upgrading to a set of splitfires, but is there anything else that can cause this?
it never missed at all when i had the wrong plugs in, but it was backfiring a fair bit when the other plugs where in. the backfiring has faded away a bit, but now i have this miss when im sitting at traffic lights.
thanks for your help in advance
cheers
jarryd
https://www.sau.com.au/forums/topic/151733-missing-at-idle/
cheers
jarryd
smaller ur gap more its gona miss fire on idle...i noticed mine really bad wen i regapped my .8 plugs down to .6 every morning i would start it up and it would sit there miss firing..so gay...
https://www.sau.com.au/forums/topic/151733-missing-at-idle/#findComment-2823575
it may be your coils are just weak, but check your ignighter as well, may be stuffed.
also give your afm a check and clean if it needs it! may cause a rough idle
ok cool. will clean AFM.
how do you check the ignitor?
if i buy splitfires, is it a waste, or precationary mod anyways?
thanks.
https://www.sau.com.au/forums/topic/151733-missing-at-idle/#findComment-2827558
Depending on how much you are going to mod your car and how stuffed your stock coils are. My coils started Popping at 4500revs but I fixed them with silicon. I also changed from Iridum 1.1mm Plugs to Copper 0.8mm. Im running 12psi and havent had a problem since. If i had extra money I would buy Spitfires but otherwise $600 can be spent on alot better things, such as fuel pump, boost controller, front/dump pipe, Intercooler, Injectors, Lighten Flywheel, Turbo.
https://www.sau.com.au/forums/topic/151733-missing-at-idle/#findComment-2828262
My car has a very very very slight mis at idle but never ever misses anywhere else, I'm running Iritop plugs (factory gapped at .6) and splitfires. From what I've seen/heard the lower gap is the culprit and so long as it's not doing it anywhere else in the rev range you should be fine.
Splitfires will help depending on what boost/power levels you want as they give you (when coupled with better plugs) a nice strong spark.
https://www.sau.com.au/forums/topic/151733-missing-at-idle/#findComment-2829215
ok cool thanks.
have been having a discussion with a mate, and he says if i change the coils the AFRs will be changed and will need a retune, is this true?
btw cars mods are full exhaust, fmic, bleed valve, bosh 040 pump and ecu remap.
and totally off topic, i have take off pretty much all of my wanky parts (bov and pod) and put stock items back on. does this also affect, or will it help? as in the AFRs.
thanks.
https://www.sau.com.au/forums/topic/151733-missing-at-idle/#findComment-2830807
It's usually a good idea to tune again for new parts but that dpeends on what they are. Normally coils are put in to assist with higher boost levels so a re-tune is mandatory in your situation it shouldn't be necessary.
Removing the POD will have bugger all affect (see that various cars are making crazy power with stock airboxes and panels etc) but the BOV will have an effect as having a venting BOV upsets the amount of air in the system typically meaning the car will run rich as there's less air in the system at combustion time than there was when the calculations were made.
Anyone feel free to correct me :) Especially about the coils
Edited by ActionDan
https://www.sau.com.au/forums/topic/151733-missing-at-idle/#findComment-2830929
UPDATE:
fitted my Splitfires last nite, there is still a bit of a miss at idle...
now i remember a while ago, i had a backfire issue with my car, and nissan played around with the timing, could this be related in anyway?
should i borrow an igniter to see if thats the problem?
thanks again
Jarryd
https://www.sau.com.au/forums/topic/151733-missing-at-idle/#findComment-2863324
the miss at idle might be timing related with the lower gapped plugs, i would check that you car is at 15 degrees at idle if manual and 20 if auto.
also i recommend split fire coil packs i have them in my car and i haven't had any ignition related problems since
https://www.sau.com.au/forums/topic/151733-missing-at-idle/#findComment-2864190
Could it be the oxygen sensor thats not sending a signal making it run that bit more richer at cruise and idle? Cos mines missing @ idle aswell but i've got a bigger turbo making it run richer but i havn't tuned it as yet, when i tune it i think it will fix my problem...
https://www.sau.com.au/forums/topic/151733-missing-at-idle/#findComment-2864218
UPDATE:
Cleaned AFM last nite...
problem still there....
should i get it re-tuned, and see how things are going, as in Timing, AFRs. etc?
thanks.
Theres a way to check the oxy sensor... i think with a multimeter to see if its actually sending a signal to the ecu, probably check that its sending a signal before you get it retuned... seeing a tune will cost $450-$500 compared to an 1/2hr of your time to check the sensor and an odd $75 if its faulty...
https://www.sau.com.au/forums/topic/151733-missing-at-idle/#findComment-2873012
    • It really depends on your setup. Mine is 'accidently' more suited to revving higher. bigger cams, turbo etc. Plus my super long first takes donkey years to come onto boost, so if it will move my power band to the right, maybe i'll pass on this. i have a G45-1500 going on there soon which I suspect might make it more of a fat pig.
    • Yeah good call, I will endeavour to tuck that down when I rewrap the looms it’s pushed up by
    • Good work. I will say, this line circled however, will potentially pool with oil, as it's going from high, to low, to high, before heading downwards.
    • Yeah, thumbsup from me. The distant shot of the bay just looks same-same as before.
    • Dad had a court case drag out with them from 1998 to 2004. He was in a not at fault accident, NRMA were the ones who covered the other person. They tried to blame his neck injuries on the fact he'd had an injury in 1981 on his extreme lower back where he slipped a single disc right near the bottom. Had been all cleared from that injury for years. This accident destroyed his shoulder, and f**ked a heap of discs in his neck, and he still has major problems with it to this day. Sarah's sister while on her L plates had a small Suzuki Alto, she had stopped to give way to an ambulance, and someone changed lanes behind her because there lane was also slowing, and rear ended her at 80km/h. (She had been stopped for a few seconds already too!). Car was completely f**kED. NRMA sent the vehicle around to 3 different workshops as they kept claiming "We believe it can be repaired, and not written off, we just need to find the correct workshop". It took 3 months, and a lot of arguing before they'd concede and wrote it and paid out. About two years later her sister had a Lancer, someone pulled out of a stop sign without stopping (in an 80 zone). Her sister swerved, hit the front of the other persons car (Instead of dead t-boning the drivers door), which ramped her Lancer, and made it roll multiple times down the road. It hit every panel on the way through. Her sister had slid her self out of the car, and remembers the ambos walking to the accident (They'd been sitting at a set of lights just down the road and witnessed it) and they were saying "Well, this ones going to be a fatality, no way you can walk away from that". Well, she did. And then NRMA sent two assessors out to look at the car, both of which wrote it off. They tried to send another assessor out, except a HUGE uproar was raised, and they FINALLY paid it out. That was on a car, that had damage to EVERY panel, you could see from 100m away the whole car was also twisted, roof bowed etc. Nah, we'll try get out of needing to payout on a $10,000 car... Her sister ended up with major shoulder reconstructive surgery being required, and was permanently limited in her ability to do her job as a nurse after that, as she can't (And was told before surgery too this would be guaranteed to happen) regain full strength in that shoulder. However, there was no choice to not have it, as she could barely use her arm, which was her dominant one, and was in near constant major pain. (And she's the type of person that would try and walk off a broken leg!) NRMA did the biggest run around on the personal injury side too for about 18 months, even to the point of trying to put 100% blame of the accident on Sarah's sister, even though the other driver admitted she didn't look, and didn't stop, and was charged by the police. Sarah used to have a Barina insured with them. It was a policy setup, paid all 12 months in advance. At the end of the 12 months, Sarah was living with me, I reviewed the renewal, it clearly stated "If you do nothing, your policy will cease on XYZ date". We did nothing, as we moved her insurance in with all of mine and I was with Shannons. We find out 10 months later, NRMA decided, because he DAD had a car insurance policy at the same address as what Sarah's mailing address was (Garaged address had been changed), that they'd put Sarah's (What should have been non existent policy) onto her Dad's month to month charges on his credit card. We had to jump through hoops, to get a refund. They didn't care that we actually found the letter that said "If you do nothing, your policy will cease" they made us prove we had NON COMPULSORY insurance else where before they'd issue the refund, and after they agreed to the refund, it still took another 6 weeks and 3 more phone calls for them to actually process it. They also had two insurance claims from storm damage, and they were an absolute cluster to get resolved as well (one vehicle, one house). Some how, up until about 3 years ago, her parents were still loyal to NRMA too, and we were like "How the hell are you so loyal to staying with them, when other places are so much cheaper, and they've f**ked you over every time you've ever had to make a claim?"
