Hye guys, i just changed my plugs to NGK's, gapped at 0.8.
when i had a major service done, they put in either 1.0 or 1.1.
now, i have noticed that it has a miss at idle, but not high up in the rev range, ie not 4500 and beyond.
now, i will be upgrading to a set of splitfires, but is there anything else that can cause this?
it never missed at all when i had the wrong plugs in, but it was backfiring a fair bit when the other plugs where in. the backfiring has faded away a bit, but now i have this miss when im sitting at traffic lights.
thanks for your help in advance
cheers
jarryd
https://www.sau.com.au/forums/topic/151733-missing-at-idle/
cheers
jarryd
smaller ur gap more its gona miss fire on idle...i noticed mine really bad wen i regapped my .8 plugs down to .6 every morning i would start it up and it would sit there miss firing..so gay...
https://www.sau.com.au/forums/topic/151733-missing-at-idle/#findComment-2823575
it may be your coils are just weak, but check your ignighter as well, may be stuffed.
also give your afm a check and clean if it needs it! may cause a rough idle
ok cool. will clean AFM.
how do you check the ignitor?
if i buy splitfires, is it a waste, or precationary mod anyways?
thanks.
https://www.sau.com.au/forums/topic/151733-missing-at-idle/#findComment-2827558
Depending on how much you are going to mod your car and how stuffed your stock coils are. My coils started Popping at 4500revs but I fixed them with silicon. I also changed from Iridum 1.1mm Plugs to Copper 0.8mm. Im running 12psi and havent had a problem since. If i had extra money I would buy Spitfires but otherwise $600 can be spent on alot better things, such as fuel pump, boost controller, front/dump pipe, Intercooler, Injectors, Lighten Flywheel, Turbo.
https://www.sau.com.au/forums/topic/151733-missing-at-idle/#findComment-2828262
My car has a very very very slight mis at idle but never ever misses anywhere else, I'm running Iritop plugs (factory gapped at .6) and splitfires. From what I've seen/heard the lower gap is the culprit and so long as it's not doing it anywhere else in the rev range you should be fine.
Splitfires will help depending on what boost/power levels you want as they give you (when coupled with better plugs) a nice strong spark.
https://www.sau.com.au/forums/topic/151733-missing-at-idle/#findComment-2829215
ok cool thanks.
have been having a discussion with a mate, and he says if i change the coils the AFRs will be changed and will need a retune, is this true?
btw cars mods are full exhaust, fmic, bleed valve, bosh 040 pump and ecu remap.
and totally off topic, i have take off pretty much all of my wanky parts (bov and pod) and put stock items back on. does this also affect, or will it help? as in the AFRs.
thanks.
https://www.sau.com.au/forums/topic/151733-missing-at-idle/#findComment-2830807
It's usually a good idea to tune again for new parts but that dpeends on what they are. Normally coils are put in to assist with higher boost levels so a re-tune is mandatory in your situation it shouldn't be necessary.
Removing the POD will have bugger all affect (see that various cars are making crazy power with stock airboxes and panels etc) but the BOV will have an effect as having a venting BOV upsets the amount of air in the system typically meaning the car will run rich as there's less air in the system at combustion time than there was when the calculations were made.
Anyone feel free to correct me :) Especially about the coils
Edited by ActionDan
https://www.sau.com.au/forums/topic/151733-missing-at-idle/#findComment-2830929
UPDATE:
fitted my Splitfires last nite, there is still a bit of a miss at idle...
now i remember a while ago, i had a backfire issue with my car, and nissan played around with the timing, could this be related in anyway?
should i borrow an igniter to see if thats the problem?
thanks again
Jarryd
https://www.sau.com.au/forums/topic/151733-missing-at-idle/#findComment-2863324
the miss at idle might be timing related with the lower gapped plugs, i would check that you car is at 15 degrees at idle if manual and 20 if auto.
also i recommend split fire coil packs i have them in my car and i haven't had any ignition related problems since
https://www.sau.com.au/forums/topic/151733-missing-at-idle/#findComment-2864190
Could it be the oxygen sensor thats not sending a signal making it run that bit more richer at cruise and idle? Cos mines missing @ idle aswell but i've got a bigger turbo making it run richer but i havn't tuned it as yet, when i tune it i think it will fix my problem...
https://www.sau.com.au/forums/topic/151733-missing-at-idle/#findComment-2864218
UPDATE:
Cleaned AFM last nite...
problem still there....
should i get it re-tuned, and see how things are going, as in Timing, AFRs. etc?
thanks.
Theres a way to check the oxy sensor... i think with a multimeter to see if its actually sending a signal to the ecu, probably check that its sending a signal before you get it retuned... seeing a tune will cost $450-$500 compared to an 1/2hr of your time to check the sensor and an odd $75 if its faulty...
https://www.sau.com.au/forums/topic/151733-missing-at-idle/#findComment-2873012
    • Also, a tip for young players  Check the dates on new tyres before they fit them, I always ask this question at the tyre shop, as they have tried to put "new" tyres on one of my cars a few years ago, but the build date was about 3 years old
    • Yeah - 4 or 5 years is the limit for decent tyres. Pedestrian grade tyres with 400 TW ratings start out hard and don't start to suffer until they are somewhat older again. But the stickier decent stuff? Nup. My current ADO9s are < 2 yrs old, 17000km in, only have about the minimum 2mm of tread depth left, and they are.....not what they used to be. They are clearly much harder now than when new. Whether that is heat cycles (unlikely, for a road tyre), different compound between top and bottom of tread, or actually aging out (in less than 2 years!!!) is not really able to be discerned. But I'd credit actual aging as being at least part of the cause. I've got an old pair of ~50% worn AD08Rs in the shed that I really need to get rid of. They started feeling waaaay too hard to put back on the car after a couple of years sitting there.
    • Personally I wouldn't put tyres over 4 or 5 years old on any of my own cars. Once they go hard the grip characteristics completely change. As per most things it only matters in an accident and that's when you most want them to do their job!
    • I'm replacing the front tyres on the E39 tomorrow because one of them has a few gouges out of it. There is so much tread still on them but they're also 9 years old and the rubber is super hard.  This falls within the guidelines of 10 years old that I've read which surprises me given their condition.  I'm curious about whether you guys care about tyre age or just judge the tyre based on condition? How old would you consider too old?
    • What starts as a scratch, becomes a flesh wound, then quadruple amputation. Jus' sayin'. Crush resistant gloves (The ones with the rubber strips down the back of the hand and fingers) might not be a bad idea after all!
