may i suggest while you are at it, add in nulon diff treatment to the transfer case. I added everyting on mine except the engine and power sterring for the diff treatment and its much smoother.
Probably more a question for those running manual Stageas but what sort of oil are people running in their transfer case? I've got some Elf stuff in mine (can't remember grade) but just curious
What's the difference between a manual and automatic transfer case?
:( cheers :(
:thumbsup: cheers :woot:
hey gary they are actually different as i have had both a gtr manual tf case and a stagea auto tf case on the bench disassembled totally side by side. its nuthin to do with its operation, only the auto one is alot less heavy duty in its parts and most noticable is the gtr one has 6 lugs pressing onto the clutch packs and they stagea one only has 4 lugs instead so alot less surface area to press the clutch packs together.
thats my useless 2c worth :P
thats my useless 2c worth ;)
Yeh, yeh, we know. But we were talking about transfer case oil. So the question was what is the difference between the oil you use in a automatic transfer case and a manual transfer case.
And the answer is....................
NONE
:yes: cheers :rolleyes:
LOL yea they are the saeme. BTW when did Bp bought Castrol? I thought Castrol is an american company?
Castrol was listed on the London Stock Exchange, so it's hardly American
BP announced the take over in March 2000.
I suggest that you had better go back to your previous post and remove the incorrect statements, some people may read them and get the wrong idea.
We have used ONLY Castrol lubricants in the race and road cars for over 20 years and never had one lubricant related problem. No, I don't work for Castrol and never have. No, I don't sell Castrol products and never have, I just use them (with total confidence).
:miner: cheers :laugh:
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
