So i don't need any new lines, just swtich them over and its done. From what i understand, these are pretty much bolt on ain't they. I'm going to get my machnic to do this but i just want to make sure that all the aprts are avaliable for the job.
https://www.sau.com.au/forums/topic/151757-r34-n1-onto-r32/#findComment-2823439
i made 410hprw last time on around 22 pound, i have n1 piston's cams and unknown rest of motor.
dont quote me on same lines but they do appear to be a straight swap.. hopefully someone else can clear that up
Edited by Angus Smart
https://www.sau.com.au/forums/topic/151757-r34-n1-onto-r32/#findComment-2823972
i got the actuators. Sweet, so its a easy off and on job then.
Easy....hmmmmm... I didn't say easy , depends who is doing it . Someone that knows what they are doing, should do it in 4 -6 hours depending on what goes wrong, its a tight fit in there ...No mods needed though, direct fit .
https://www.sau.com.au/forums/topic/151757-r34-n1-onto-r32/#findComment-2824340
Yep, i've got some trust extension pipes to go on at the same time. Thought i might as well do this all at the same time >_<
i've also got bosch 044, power fc and JB clutch.
My machanic knows GTRs inside and out, its eric from hypertech. He worked on the winfield car :)
His also doing the tune.
Whats a safe level to aim for with standard injectors?
Are you upgrading the dump pipes/manifolds at the same time?
https://www.sau.com.au/forums/topic/151757-r34-n1-onto-r32/#findComment-2825237
    • Please do not connect it to your manifold. If you do, as GTS suggested please record the lot in 4K with good mics attached.   On the factory Skyline, there's a upside down pipe that allows it to breathe, looks like this
    • For me I'd need some serious justification for why it has blown out.  Have you questioned him on it?  To be honest if you didn't question him right from the get-go on the first invoice that was already way over the initial quote and then you've (presumably) then paid another $1375 on top of the first invoice, then you're pushing shit uphill to get a favourable result now... It was years ago I last got an engineer out but it was around $450-$550 per visit.  That was just to inspect each progress point he gave me for the project.  Is he just doing progress inspections or is he providing engineering diagrams, technical assistance, etc??  If he's not, he's a filthy rip off merchant.  If the $3100 is the final sign off then you need to cop it on the chin, pay it and move on.  If it's not, piss him off and get a new one.  Not many Jeeps I'd value at $10K full stop let alone just engineering fees on a written off, half actual value WOVR Jeep....
    • Oh, yes. If you connected it to the manifold your first drive would be very eventful. Very shit. Very interesting. Perhaps take a video if you feel the need to see. Terminating the breather at the top of the bellhousing is normal/stock. Some gearbox lubes (hello Redline Shockproof) like to foam up a bit and require the breather to be extended up higher, so you don't get spots of smurf jizz staining the floor under your car. Mine is thus right up behind the head. Make sure you fit a u-bend at the top so it points back downward so that dirt and schmutz has a harder time getting into it.
    • Cheers for the replies. So i don't connect it to the manifold I just run the hose high up on the firewall?
    • It doesn't really answer your question...but is the head unit full android or just android auto, are you happy with how quickly it boots and responds, and do you have a link?  If we can identify good Android alternatives it will really help people stuck with Japanese screens. Did it have a separate reverse camera input so you would replace the factory one, or are you just going without now...that would be a pretty big steps back. And finally, do you have a picture of the "wire" that you can't plug in? Most likely it is some sort of aerial that is not too important eg japanese traffic or am radio or something if you haven't noticed a functionality issue
