if it is an after market bar they are only held ony by like 4 or 5 bolts.
but if it is the plastic one then the bolts are all the way around
so go to wheel and undo the outside ones and undo them one by one and the bar should rap off if u get what i am saying....
When I had my car at the exhaust place getting some work I wanted them to adjust my IC pipes and re-position the IC. They said they couldn't get my S1 M-Spec bar off coz it was joined into black plastic behind it...
Anyone know anything about this ?
WTF ? sounds like they didn't know what they were doing and making excuses (common workshop practice).. on mine at least (series1) which has an aftermarket GTR style bar.. although they are much the same i think .. push plastic splash guards in .. remove few screws (2 or so.. or maybe just the one) on left and right side of the bar, bolting bar to side panels. U might need small screw driver, not heaps of room to do it. Some may have had plastic ties to tie the bumper to the splash bits to secure them in place.. just cut them off and replace later.
Now get underneath and there should be 2 support rails where it bolts in the chasis and 2x 14mm bolts each side (from memory, or it could be a 16mm) that holds it in.. You may need a "long socket" (about $8 from a tool place) as the thread comes out a fair bit from the nut. Now undo those 2 bolts on each side.. get something soft to put it on so you don't scratch it.. and simply slide out. You may at that point also need to disconnect the indicators plugs and things.
Hope that helps.
It does and I do think they were making excuses. Don't spose anyone has pics of where all the bolts and stuff are, much easier then me spending an hour looking for all these hidden bolts (or disconnecting the wrong thing).
  • 1 year later...
  • 1 year later...
hey this would really help me guys, the 2 x 14mm bolts on each side, are they to take off the reinforcement bar as well???, these things are ultra hard to get out, any help pleasE??wrong tools maybe?
heres the order ive done for my r33 series 1 front
pull out the grille (5 plugs)
unplug screws below the grille
-Behind the plastic inner wheel arch guard there's two screws either side which hold the sides of the bar to the front of the guards.
Edited by nsta
  • 7 months later...
  • 1 month later...
In my experience in removing my factory S1 front bar, there were 2 bolts either side where the front bar meet with the guard, near the wheel arch.
There were then 4 bolts underneath the front bar, staring the the ground. A simple philips screwdriver will get these 4 out. There are 2 on both sides.
There were then 3 clips underneath the grill. When I say grill, I mean the little section that clips onto the headlights and sits between the bonnet and front bar.
Sometimes, you will get lucky and removing these 8 bolts and 3 clips is enough. However, there is a large clip underneath each headlight that the bumper slides under. A flat head screw driver to pry these up will do the job. If you haven't got a tool suitable, you may need to remove the headlights. If this doesn't help, send me a PM and I'll ATTEMPT to draw up a diagram.
  • 4 months later...
I can't seem to find the 4 bolts facing the ground. I found 2 facing the front of the car, underneath the grill. I found the 3 clips underneath the grill. Hmm...
I couldn't get the 2 clips off on each side that were attaching the front bar to the guard... philips head just ate the plastic. Tried destroying them with some clippers but the plastic is too tough. Anyone know how to get the clips off without a philips head...?
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
