if it is an after market bar they are only held ony by like 4 or 5 bolts.
but if it is the plastic one then the bolts are all the way around
so go to wheel and undo the outside ones and undo them one by one and the bar should rap off if u get what i am saying....
When I had my car at the exhaust place getting some work I wanted them to adjust my IC pipes and re-position the IC. They said they couldn't get my S1 M-Spec bar off coz it was joined into black plastic behind it...
Anyone know anything about this ?
WTF ? sounds like they didn't know what they were doing and making excuses (common workshop practice).. on mine at least (series1) which has an aftermarket GTR style bar.. although they are much the same i think .. push plastic splash guards in .. remove few screws (2 or so.. or maybe just the one) on left and right side of the bar, bolting bar to side panels. U might need small screw driver, not heaps of room to do it. Some may have had plastic ties to tie the bumper to the splash bits to secure them in place.. just cut them off and replace later.
Now get underneath and there should be 2 support rails where it bolts in the chasis and 2x 14mm bolts each side (from memory, or it could be a 16mm) that holds it in.. You may need a "long socket" (about $8 from a tool place) as the thread comes out a fair bit from the nut. Now undo those 2 bolts on each side.. get something soft to put it on so you don't scratch it.. and simply slide out. You may at that point also need to disconnect the indicators plugs and things.
Hope that helps.
It does and I do think they were making excuses. Don't spose anyone has pics of where all the bolts and stuff are, much easier then me spending an hour looking for all these hidden bolts (or disconnecting the wrong thing).
  • 1 year later...
  • 1 year later...
hey this would really help me guys, the 2 x 14mm bolts on each side, are they to take off the reinforcement bar as well???, these things are ultra hard to get out, any help pleasE??wrong tools maybe?
heres the order ive done for my r33 series 1 front
pull out the grille (5 plugs)
unplug screws below the grille
-Behind the plastic inner wheel arch guard there's two screws either side which hold the sides of the bar to the front of the guards.
Edited by nsta
  • 7 months later...
  • 1 month later...
In my experience in removing my factory S1 front bar, there were 2 bolts either side where the front bar meet with the guard, near the wheel arch.
There were then 4 bolts underneath the front bar, staring the the ground. A simple philips screwdriver will get these 4 out. There are 2 on both sides.
There were then 3 clips underneath the grill. When I say grill, I mean the little section that clips onto the headlights and sits between the bonnet and front bar.
Sometimes, you will get lucky and removing these 8 bolts and 3 clips is enough. However, there is a large clip underneath each headlight that the bumper slides under. A flat head screw driver to pry these up will do the job. If you haven't got a tool suitable, you may need to remove the headlights. If this doesn't help, send me a PM and I'll ATTEMPT to draw up a diagram.
  • 4 months later...
I can't seem to find the 4 bolts facing the ground. I found 2 facing the front of the car, underneath the grill. I found the 3 clips underneath the grill. Hmm...
I couldn't get the 2 clips off on each side that were attaching the front bar to the guard... philips head just ate the plastic. Tried destroying them with some clippers but the plastic is too tough. Anyone know how to get the clips off without a philips head...?
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
