i should make a 67 easy with the current setup, i still got to put new plugs in, the new ported intake plenum and intake pipe and0 adjust the timing.
Might leave the new brake pads and lines for the next round rather than rush them on
isn't that only 1 sec?
haha yeah yeah - im just bored....
see the way i thought of it is when you (well me anyway) say something like "hopefully beating my old time of 1:08" (or or what ever the time may be) means your going to try and beat it but your not confident and will probably still be in the 1:08's just hopefully just a bit better. On the other hand saying something like "easily get 1:07" indicates it will most likely be a low 1:07...
anyways - times aren't that imporant afetrall - its all about the racing!!! /me loves it! :huh:
haha - ive never raced in the wet... sounds a little scary to be honest...
i love driving the hilux in the wet but the skyline is scary on the wet road... cant image the wet track
we race on the sprint track at SAS so they are sprint times
ok...so not many...ive seen atleast two in the 57's and heard of 1 in the 56's.
ZENNON if you rip that 20 out and stick a rb30det in there...that will change. Plus some semi slick tyres if you arent already running any.
You would be suprised how much difference a set of semi slicks will make. I have managed a 62 on the sprint layout in the sedan and I only have 175rwkw. Pretty sure I can get that down a bit further too as the tyres were pretty much dead as they were the old ones I used to run on the GTR. I did a flat 60 in the dry and a 68 in the wet in the GTR, it had about 210awkw. Plenty of opposite lock in the wet :)
that black r32 gtr that was there on the 9th dec did a 55.55 - was very cool!
nah cant afford the engine conversion!!! one word: house-payments!! (ok two words) :)
as for tyres: yeah got some cheap wet-semi's atm.. ill get proper semi's when these are dead
You would be suprised how much difference a set of semi slicks will make. I have managed a 62 on the sprint layout in the sedan and I only have 175rwkw. Pretty sure I can get that down a bit further too as the tyres were pretty much dead as they were the old ones I used to run on the GTR. I did a flat 60 in the dry and a 68 in the wet in the GTR, it had about 210awkw. Plenty of opposite lock in the wet :/
yikes!! thats crazy! (the gtr in the wet)
yeah i dont have proper semi slicks and my car doesn't have that much grunt les than 175rwkw i think (ill find out at dyno day) but yeah ive managed a 63 - and ive been getting faster the more i go and took hicas out over the holidays so looking forward to this year :)
Well i'll be there, i'm confident that i'll make the 67's, i got adjustable camber tops and castor arms in the front, bigger sway bar and pillowball tops in the rear and its a bit lower and hard now.
hopefully the new intake pipe will get me a bit more air in too.
Im not too bothered with semi slicks on mine, im only making about 100 - 110 rwKw out of my RB30e.
See you guys on saturday
Yeah over the holidays I also got the camber turned up a little, or is it down, haha, well more negative!
Semi's aren't for traction when your on the gas - it's for the corners!! My friend jezza in his n/a starlet which has no power has semi's! (little thing corners like a deamon haha - he ran a 66.55 which I thought was pretty impressive
sure will! come say hello cos i dont know what your car looks like
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
