i should make a 67 easy with the current setup, i still got to put new plugs in, the new ported intake plenum and intake pipe and0 adjust the timing.
Might leave the new brake pads and lines for the next round rather than rush them on
isn't that only 1 sec?
haha yeah yeah - im just bored....
see the way i thought of it is when you (well me anyway) say something like "hopefully beating my old time of 1:08" (or or what ever the time may be) means your going to try and beat it but your not confident and will probably still be in the 1:08's just hopefully just a bit better. On the other hand saying something like "easily get 1:07" indicates it will most likely be a low 1:07...
anyways - times aren't that imporant afetrall - its all about the racing!!! /me loves it! :huh:
haha - ive never raced in the wet... sounds a little scary to be honest...
i love driving the hilux in the wet but the skyline is scary on the wet road... cant image the wet track
we race on the sprint track at SAS so they are sprint times
ok...so not many...ive seen atleast two in the 57's and heard of 1 in the 56's.
ZENNON if you rip that 20 out and stick a rb30det in there...that will change. Plus some semi slick tyres if you arent already running any.
You would be suprised how much difference a set of semi slicks will make. I have managed a 62 on the sprint layout in the sedan and I only have 175rwkw. Pretty sure I can get that down a bit further too as the tyres were pretty much dead as they were the old ones I used to run on the GTR. I did a flat 60 in the dry and a 68 in the wet in the GTR, it had about 210awkw. Plenty of opposite lock in the wet :)
that black r32 gtr that was there on the 9th dec did a 55.55 - was very cool!
nah cant afford the engine conversion!!! one word: house-payments!! (ok two words) :)
as for tyres: yeah got some cheap wet-semi's atm.. ill get proper semi's when these are dead
You would be suprised how much difference a set of semi slicks will make. I have managed a 62 on the sprint layout in the sedan and I only have 175rwkw. Pretty sure I can get that down a bit further too as the tyres were pretty much dead as they were the old ones I used to run on the GTR. I did a flat 60 in the dry and a 68 in the wet in the GTR, it had about 210awkw. Plenty of opposite lock in the wet :/
yikes!! thats crazy! (the gtr in the wet)
yeah i dont have proper semi slicks and my car doesn't have that much grunt les than 175rwkw i think (ill find out at dyno day) but yeah ive managed a 63 - and ive been getting faster the more i go and took hicas out over the holidays so looking forward to this year :)
Well i'll be there, i'm confident that i'll make the 67's, i got adjustable camber tops and castor arms in the front, bigger sway bar and pillowball tops in the rear and its a bit lower and hard now.
hopefully the new intake pipe will get me a bit more air in too.
Im not too bothered with semi slicks on mine, im only making about 100 - 110 rwKw out of my RB30e.
See you guys on saturday
Yeah over the holidays I also got the camber turned up a little, or is it down, haha, well more negative!
Semi's aren't for traction when your on the gas - it's for the corners!! My friend jezza in his n/a starlet which has no power has semi's! (little thing corners like a deamon haha - he ran a 66.55 which I thought was pretty impressive
sure will! come say hello cos i dont know what your car looks like
    • Let's hope that's not a copy pump either. There were so many copies of them back in the day.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
