1990 R32 GTR
95 R33 GTR motor (75,000km) (standard)
OS GIKEN twin plate clutch
Power FC c/w Hand Controller (have standard ecu aswell)
Nismo 260km speedo
Bilstein Adjustable Suspension
Veilside rims (17inch)
3.5inch stainless JASMA cat back exhaust and muffler
Custom front pipes (2.5inch) into 3inch hiflow cat
PRICE $19,000 SOLD
Also have 2X GARRETT gt2560r 300hp each turbos with X-Force dump pipes (just gettin new centres at JPC now.) I want an extra $1800 for those but will seperate.DUMP PIPES SOLD!!!
$1500 FOR TURBOS
TURBOS SOLD
Please call SCOTT 0412839851
email. [email protected]
PLEASE PM OR CALL ME, AS I DONT USE MY EMAIL MUCH. Thanks
Edited by scotty_gtr
https://www.sau.com.au/forums/topic/151802-r32-gtr-1990-white-sold/
hi
will be intersted in trading in wid honda civic VTI-R 1999 2 door coupe Black 11 month rego 109000 ks timing belt change at 99ks full serives from 0 ks to now from honda dealer full log books reply at [email protected].
cheers
1990 R32 GTR
Nismo 260km speedo
PRICE $20,000
Also have old pistons, rods, crank, sump and bits and pieces from the old motor that i will throw in.
$1500 FOR TURBOS
TURBOS SOLD
hey everyone. still for sale. just spent $1100 on it. got it all serviced and tuned and new tie rod ends, ready for someone to buy. and im back from sydney. i regularly go to melbs, so if anyone wants to see it just give me a call to meet up.
cheers
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
    • I'm mark from Idaho.
