I got my new engine built and I was told it was going to have 8.8:1 compression but when i compresson tested it i got a reading of 120 in each cyl.
Now correct me if i am wrong but that is pretty low as my old stuffed engine had 150 in each cyl and that was around 8.3:1 or abouts (stock rb30e pistons)
So my question is can you convert that psi reading in the cyl to a compression ratio ? (was done warm with throttle open)
I would like to know what compression ratio it is.. looks to me that its in the 7's.. would that be right ?
I noticed the cometic head gasket looked like a shim plate. around 2mm so maybe thats why its ssooo low...
so how do i know the compression ratio of this engine? the engine builder said 8.8:1 but i dont think its there.
I dont really mind that its low because im going to add another 10psi boost and it will be fine on pump gas.. might try 25psi
cheers
https://www.sau.com.au/forums/topic/151803-engine-compression/
you know the stroke, the CC of pistons, CC combustion chamber, headgasket thickness and how far under/over the piston sits compared to the block deck. From this you can work out an accurate compression ratio.
Just by going from the guage u have a few problems, different guages and cam overlap. You have static compression ratio, and dynamic comp ratio, so when you use a comp tester the cams if they are larger or set to a different position that can bleed off more/less air, therefore changing your readings.
also, you need to go thicker head gasket when you go oversized pistons (if you want to stick to the same comp ratio), unless they dish in the piston is larger as the comp ratio will rise.
Edited by GTR1993
Getting oversize pistons makes stuff all difference to the comp, if tis the same cams as the previous motor, and has lost 30 psi, its a fair bet its running lower comp. How many k's has it done? Do you know if the engine builder cc'd the chambers, checked piston heights/squish etc. Is it an r33 head, if so i cant see any reason for a 2mm head gasket, usually you are trying to get as much comp out of them as you can, even with n/a pistons, do you know what brand of piston was used?
I had the same problem in my rb25 when it was rebuilt as i found out a year later that the comp tests shouw up as 120psi across all pistons. In the end i pulled the motor apart again and got it tested and the comp ratio was 8.1:1 with a std head gasket.
  • 1 year later...
I really dont think you can accuratley compare cylinder compression with compression ratio.
The compression ratio is just the ratio of the volume of the combustion chamber at BDC to the volume of comb chamber at TDC, its just maths, not anything to do with psi...correct me if im wrong
Doesnt take into account loosely toleranced pistons, rings etc,blow by, or long duration cams with big overlap which will all reduce the actual compression of the engine
But i guess that if engine A and engine B, were built to the same tolerances, and were up to the same temperature, with the cams cams etc, but A was 9:1 and B was 8:1 then cylinder compression should be higher in engine A
So there can be a relation but its not a guarantee
take a look at http://www.type2.com/library/engineg/comrat.htm
they have a table from the bosch automotive handbook, that relates CR to compression, going by that you could have anything from 6.8-7.8:1, thats a pretty big range, but still supports ur guess that your compression ration is in the high 7's
hope you work it out mate
Couple of calculators for you:
http://www.csgnetwork.com/compcalc.html
http://golenengineservice.com/calc/calccr.htm
Did you have the combustion chambers modified in any way - if you have then chances are the chambers will be bigger which will reduce your comp too.
I've just had an SR built an we initially installed 8.5 CP's but as the head had been modified (by JHH Engineering) we then had to install 9.0 CP's to get the static comp up to the target 8.8:1. We didn't have the head at the time the bottom end was built and had relied on general comments from JHH that the volume wouldn't vary much. Not having a go at JHH - I'm stoked with the job they did.
Just saying it pays to CC's everything and calculate the comp ratio before buttoning up the engine.
Personally I would rather run more comp, less timing and less boost. With E85 fuel coming on song I can then retune for more timing and boost.
If you really want to know the precise ratio and do not have the information to calculate it (cc of head, exact bore and stroke) then perhaps you can measure it by pouring oil down the spark plug hole at TDC and then filling it again at BDC - potentially messy (bit of a mission to get the oil out again) but dead accurate (and no, I haven't done it myself).
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
