Hey guys
I'm after a bit of information on flat boots.
I was wondering where you got yours, how much you paid etc.
Also are the standard brackets and other standard parts used or do you need new ones?
+ Has anyone just made their standard boot flat by rising it up and stuff?
Thanks,
Brett
https://www.sau.com.au/forums/topic/151832-flat-boot-on-a-r33/
Hey guys
Thanks,
Brett
hey, im also considering the going with the flat boot, although i found a nice rear spoiler at www.justjap.com called the stealth that looks sick and gives you the flat boot look.
this has been covered a bit if you do a search..
PSI parts on here sell the stealth rear drift wing for $150 i think
i have made a bootlid for my GTR here's a few pics...
Edited by Noy
My brother in-law owns a panel shop, you need to remove the standard wing, weld the hols up, then they raise and mold some fibre glass over the remaining boot lid making it even with the rear. The trick it to blend it in making it flush with the tail light making it look like factory. Any panel shop would be able to do this go around and get some prices.
ahh no....your very wrong. No offence very wrong
Edited by Silent
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
    • I was more thinking so it doesn't flop around as much rather than for rotating it. Once you have the balance right, it should rotate well enough, depending on how much resistance there is on the pivot. I think you said the pivot point was on a bearing though didn't you?
    • You can get them with the worm drive rotator but I was too tight to pay another $250-$300 so manual labour it is! I don't think it will be too hard to rotate though.
