:happy: You can convert your R34GTT to look like as R34GTR with genuine R34GTR front bar and bothside guards..
parts just for ..$1300.-
other parts also for sale...
R34GTT Tein adjustable suspension...$500
R34GTR Vspec II Nur genuine original exhaust...$250
RB26DETT new stenless 3" downpipe ...$350
R33GTST right side head light...$50
R33GTST original exhasut ...$100
R33 GTST original rims with brand new tyres...$300
R32GTR kakimoto exhaust...$400
R32GTR original intercooler....$250
Advan 17" wheels with tyres 9JJ fit to R32GTR....$500
celsior Luxus 400 airbag suspension.....$500
thanks mate
Edited by netsky
you willing to post the gtr bar to syd?
Hi ..May be able to post to syd....if you can help for the postage...
fastway couriers is very good..please visit their web and check if you like to use their service..
www.fastway.com.au
3 parts ( front bar and left and right side guards) only...
not include front bar lip
regards
Tony
Edited by netsky
Hi, how many km have the R34GTT coilovers done and what brand/model are they?
Hi Mate...it was on R34GTT with about 70000km...and will check which model....it Tein ...
regards
bothside guards? are these the rear flared guards? because not sure how you are going to seperate them but interested in buying
Hi mate....the R34GTR genuine front bar and front both side guards was sold yesterday....
thank you...
regards
(if you are looking left side guard ...then i know the guy may want to sele it...)
hey mate, can you give us some more info on the coilovers and whether ur willing to ship them at buyers expensive, very interested
Hi mate...I have after market Tein and bulsteen and nismo suspension for R34GTT...
all of them can adjustable hard and softness..it 3 level hight adjustable...please see the pic on up this page of my reply to other person...
I will put up those pics at the this weekned once I got the pics taken..
regards
Pictures of "R34GTR Vspec II Nur genuine original exhaust"?
What is the diameter of the pipe (apologies for my lack of knowledge here!)
Cheers
Luke
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
