wheres sydneykid when you need him on the afm vs map sensor debate
my tuner here in nz who's one of the best in the country says afm's are more accurate and the power fc is a great computer.
PowerFC is a good computer when you want minimum effort to get a decent tuneable ECU. I've heard patchy arguements that MAPs are better than AFMs - I've given answers to the AFM vs. MAP debate already SirRacer. I'm not going to join the arguement, but I vote the MAP sensor without hesitation.
ST mainly tunes PowerFCs, no wonder he's pro PowerFC.... if he can't tune other things, why would he tell you to go with others?
There are quite a few cases around the place of people getting over 500whp on stock internal RB25s, though at least a thicker head gasket is well recommended.
  • Replies 113
yeh thanks for all the info people i really appreciate it, and its exacully what i was looking for.
as for the power i am chasing would be between 300 and 350rwkw, so from what ive heard this shouldn't stress the rb25 alot.
the reason why i asked this question is that as we all know a rebuild could cost more than full high mount setup, so yeh i think we get the drift.
once again cheers, and keep the info roling as there could be other noobie's out there looking for this kinda stuff :)
Not joining the argument on which is best,
But Just to add to the convo on pfc's making good power, seems the japanese tuners can make good power from them, as there is a Imports mag, i was looking at with a 1200hp drag skyline with a powerFC. I believe its in the top 10 list. ill get the mag and update this post.
So theres 3 of us
Hectic
i thougt i was the only one making it up
hahhahahahahahahaha
So mr r31 nismodeiodjfgjiut
It Can be done
I never said it could not be done.
Just not reliably.
On a side note, arent you done making yourself look like a 5yr old yet? I thought you'd moved on from well... muppet posts.
Im sure its doing wonders for your business the attitude you display here.
And then, 100rwkw more than matlowth, i'd want more than an extra 4mph return :yes:
Just not reliably.
Comon man sloppy shiftin
Edited by MR331307
but I don't believe electronics are the japanese strong point.
The Japs basically invented electronics in the 80s & 90s. How old is the PFC? How old are the new ecus we are talking about? Yeah...
The issue isn't if it can be done, the issue is how long can it be done for. Most ppl dont wannt rebuild in 6 months.
Not wanting to get into an argument here, but I don't believe electronics are the japanese strong point. They excel from a basic engineering standpoint with the build quality and tolerances of their motors. Look at most Jap vs Aussie motors and you'll see that the Ford/holden built motors are the ones who use/leak oil etc, while it's the japanese cars that always have failing electronic components (oddly enough). PFC's are so popular because the Japanese have been using them for a long time & get easy and consistant results with them but really they are just a basic adjustable standard syle ecu. Then look at some of the aussie cars using Shit low tech motors and Aussie made ECU's and tuning knowhow, and they break all the rules. V8 supercars is a good example of a basically shit motor tuned within a inch of it's own life.
Short answer is PFC = Easy option/Path well travelled
Don't mean to offend anyone. Just my two cents.... I realise this may be considered an unfair generalisation, but it rings true in a lot of cases
Are you kidding?? Where do you go to buy a good camera from? I buy japanese if possible. Sure a lot of stuff is made in other countries now but the japs started it. I'd much rather own a japanese car of the 90's than some of the local crap - my 1994 gtst's electronic components haven't missed a beat in 4 years of ownership and the same goes for the 1988 nissan silvia I owned before. Compare a 90's gtst to a ford falcon of the same era and the falcon will lose reliability wise - mechanically and electrically from leaky oil seals to electronic autos that go crazy.
Most electronic problems people get with nissans are caused by dodgy workmanship ie. butchering the loom to fit an aftermarket computer. I recently helped pull an engine out of a 94 vs commo v6 - so many stupid ideas mechanically and electrically it was unbelievable. The japanese build quality from wiring to mechanical components to the electric windows is far superior.
Pfc's are the best computer you can buy for a skyline bang for buck - if you want to compare it to other aftermarket computers you'll have to go back a lot of years as pfc's have been around for a long time now. And look for a computer that's the same price that you can just plug in and drive away with + 15 rwkw and nice maps. I think you'll be looking for a long time.
As for v8 supercars making huge power - give any large capacity engine strong components, good breathing, high rpm, good tuning from the latest top quality expensive aftermarket computer - of course it will make big power.
I have heard that Power FCs are rubbish from people and to use just an SAFC and then when I come on here every1 hails Power FC again...
Do you think the D-Jetro version of the Power FC is better then because it doesn't need a AFM from under the hood?
This is important to me because I am torn apart from this descision of what ECU or Management system to get. Haltech I have heard tho are good ALL ROUND.
Paul,
Its the afm bashers that slag the PowerFC.
If your only going to use the car for street duties and maybe the 'occasional' track use grab a regular powerfc. They are fine, have knock control, return good fuel economy, cold and warm start perfectly. They are an excellent ecu.
If you've got plans for 300+rwkw and your really going to sink some $$ in to the car throw 2-3k+ ecu in to it and be done with it
So should I aim for 290kw then instead of aiming for 300 on a power fc... my original plans had power fc and still do but alot of people still say no to it... why? I want a hand controller its so cool... lol.
Who exactly says no to it?
The majority of people on this forum run a PowerFC, the minority don't.
There's nothing wrong with the pfc apart from the issue with obtaining an afm with high enough resolution for 300rwkw+.
Once the afm runs out of resolution you tune it crudely, similiar to that of a map based ecu.
The SAFC is fine if you are sticking with the std turbo.
Anything bigger and you WILL NEED an aftermarket ECU. The SAFC will not cut it as you will experience that funky R&R.
If you have plans never to throw a larger turbo on it is difficult to justify the 1k on a PowerFC + tuning. In my opinion anyway.
A s/h SAFC can be picked up for $200-$300, throw a cheap $30 bleeder on cheap fmic kit, s/h cat back, an hour or two on the dyno $100-$200 and its done.
The PowerFC will give you more average power and better economy over the SAFC, but for $700 is it worth it? Thats up to you. :)
The SAFC is really for those RB's setup with a cheap bleeder, cheap fmic kit and a second hand exhaust. If your going to throw money at the car and throw a decent $700+ FMIC, good exhaust, EBC etc you may as well throw another $700 at it for the better ecu.
I think you know what I am getting at.
Cubes, you are right as per PM to you late last year I told you I am putting quality shit on my car, and I know to go Power FC. Regardless...
I am putting a bigger turbo on, I am putting a 700 dollar FMIC kit on once I get the word its available, and I am going to put in a PFC, problem is tho due to turbo dieing faster than i expected, I am forced to put on a bigger turbo now, fmic quickly after and do the stuff i planned to do over 3 months over around 5-6 weeks.
    • I found the same with Subaru’s.  I own and love the SG9 Forester, after that model 2008+, Subaru threw the ugly stick at all their line up and somehow managed to make them look worse with every succeeding year.  lol
    • It's something we all have to consider as time marches on. Also consider lifted rally MX5 conversion at that point.
    • I should be fine for a few more years, whilst I do have arthritis I also exercise and do mobility training every day to keep as fit and healthy as I can, military life, which is the actual cause of most of my joint issues, has set daily regimes, which I weirdly enjoy I also train alot smarter now, not really focusing on lots strength or puffy muscles, I'm more focused on maintaining what I have for my future older self, I actually train as much mobility now as I do exercising Check out this "simple" drill I have been doing daily prior to training now for a while now, this has worked wonders in my all round mobility
    • I'd say one thing that may make you sell is the same reason the guy with the hard top roof sold his. He got old, and his back was giving him too much grief stopping him getting in and out... Old guy said he was 73! He looked and sounded younger than 73 to me! Or maybe I'm just aligning with old people more...
    • Already looked at a few prior to getting the MX5, really nice car, had all the mod cons, but I wasn't really sold on the new "look" I did miss my 2017 Limited, and I personally prefer the "look" of the older car over the new model, but, when pondering I kept going back looking at MX5's But it was same same for the new ND's, I wasn't sold on the new "look", especially the RF with its weird roof, which only half goes down, like a targa top sort of thing As I stated before, I did look at NC's, but the cars I looked at were PRHT's, but I didn't like their roof line "look" of the PRHT, until I saw the soft top version, (someone on SAU posted a for sale ad for one with a soft top that caught my attention, you can blame them for my choice.....🤣) and.... that old style detachable hard tops were available for them, which keeps the old MX5 more smoother flowing roof line, and the more rounded body style, similar to the NA-NB, to me, the arse end of the ND looks to "modern" Much like how I prefer the NC1 front bar, over the later models How long will I keep this car for is unknown, but currently, there's nothing else out there that "floats my boat" for a small, fun, little "sports car", that I can play with and enjoy looking at and driving But, who knows what the future holds, and going off current new car styling, if I replace it, it will be a older model something something
