rb30 stainless steel manifold
2.6mm Thick, 45mm Piping
t04e turbo
3" Inlet Diameter : 2" outlet
Wet Floating Bush Bearings : 1/8 NPT oil inlet
T3 Flange : Fits T3 and T3/T4 Manifolds
Specs: .50 a/r compressor, .63 a/r turbine, .57 trim
Turbine wheel: Exducer: 2.48" Mayor : 2.89"
Compressor wheel: Exducer: 2.07" Mayor : 2.36"
wastegate38mm wastegate
this setup is good for 600hp ive changed the way i wanna go now so i have no need for all this as im sticking with an rb20
it all lives in my wreck so i gotta go round and take some photos and ill post them up when i get them
will sell separatly as long as all parts are accounted for but prefer to get rid of it all at 1nce
turbo $550
wastegate$150
manifold$510
all together $1100 neg
https://www.sau.com.au/forums/topic/151869-fs-t04e/
t04e turbo
turbo $550
wastegate$150
manifold$510
wat brand turbo? used im assumin and whens it hit full boost?
https://www.sau.com.au/forums/topic/151869-fs-t04e/#findComment-2825422
not too sure on the brand mate i brought it off ebay
never used it but ive been in a 32 running this turbo and it was unbeliveable
https://www.sau.com.au/forums/topic/151869-fs-t04e/#findComment-2827770
how would this turbo go on a rb20???? pics???? where are you located????
im located in brisabane
it goes well on a rb20 makes full boost sumwhere around 3800 4200 i think from memory
i have gotten around to taking the pics yet
https://www.sau.com.au/forums/topic/151869-fs-t04e/#findComment-2827843
    • And 90% of the time those people turn out to be wrong anyway. But they still treat themselves as a victim...
    • I used the radium thing, makes the whole parallel assembly a lot more compact compared to any other way of doing it
    • Racetronix also sells those ethanol content sensor bypass blocks. Adapter, Flex-Fuel E85 Sensor High-Flow Bypass, In-line No Sensor (ADF-FLEX-NS): Adapters - Flex Fuel | Racetronix Ethanol content sensor are originally designed to be on the feed line. These bypass blocks are meant to be ran in the feed line and not return. The continental ethanol content sensors have a 3/8" ID and not 5/16". This is why they are ran on the return line directly in conjunction with a low threshold sampling value VS in the feed with one of these blocks.    Haha we think alike, I used both original feed/return for 8AN feed, and one of the Hicas lines as a 6AN return. I also capped off and left the other Hicas line as a spare.
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
