Ok, before i get flamed ive done a search and i couldn't find a conclusive thread about this.
This is basically a question/info thread
Question: i want to get an ECU for my car (r33 rb25DET), and wanna know the main differences and adv/disadv about each one.
So far I've worked out that:
- Apexi FC is the easiest to tune, u can achieve a better tune, its relatively cheap ($1200) its got a hand controller, good resale value and very reliable. Bad points are it uses AFM and does not have a boost controller
- microtech is better for racing but not good for street since it is harder to tune for part throttle and to tune for economy. Alot of tuners are also not competant using it which means more dyno time is needed (= more $$$). Not sure how much the unit costs but it is slightly more expensive than AFC i think. Good thing about this one is that is uses a map sensor instead of an AFM, so no need to upgrade to z32 AFM.
-wolf3D, is the 1 i dont really know anything about. Apparently its good tho.
-Greddy emanage, apparently is more a A/f controller mush like the apexi SAFC, altho its got more features than a SAFC. Compared to an AFC, i'm not sure which ones better. E-manage can be obtained for under $400 from nengun.
- remap, is a ok option if u plan to do no more mods on ur car. If u do, expect to pay 600-700 for each retune (which is only slightly more than a dyno run) but more importantly u are locked into the 1 tuner. Gains are also not as good. Dr-drift chargers less than 1000 from memory for the 1st remap.
So far this is what ive understood. My car is a street car with very little track time and a stock turbo/afm/injectors. Im on a budget of (max $2000 drive away) and would like to hear pples opinions/experienced to help me decide which way to go.
https://www.sau.com.au/forums/topic/151907-ecu-for-r33-rb25det/
EMS
http://www.skylinesaustralia.com/forums/in...;hl=Which++ecu*
PowerFC or Microtech
Microtech or Link
http://www.skylinesaustralia.com/forums/in...=128762&hl=
There are a dozen other threads, each asking for peoples personal experience... yadda yadda yadda. Im sure you get the idea.
End of the day its a case of choose the ECU your tuner feels most comfortable/familiar with using.
Your ECU/Tune/Car performance will only ever be as good as the tuner, decide on a workshop/tuner and go from there.
Thats the common denominator you have grossly overlooked
that's so true, I dunno how many people I have spoken to who have complained about the tuning job such'n'such workshop did but it was like the first time they had even dealt with that ECU.
I was speaking to the guys at UAS the other day about the PowerFC and if there was going to be anything to replace it from Apexi and they said they didn't have any info, but were going to start working with the E-Manage 2 in the not too distant future and said depending on the ease of tuning (and how long it takes the tuner to get it down-pat) it shoudl perform just as well if not better than the PowerFC.
the powerfc has a boost control kit, its on www.nengun.com
using an afm is a good thing, using a map sensor is not
the emanage is a piggyback and always will be, so i dont see how it would be better than a replacement stand alone
im in a similar boat at the moment and i agree, the information out there is not conclusive... it isn't that easy to find PFC's and your still up for $600 a tune... as long as you dont want much more than 220rwkw, its probably not necissary either. Here are the obvious options as far as piggy back ECU's go - can anyone provide info as to tuning costs for these and any other information ive missed or am unsure about:
Apexi SAFC 2
$320 delivered (2nd hand)
+ 2 saved maps (cruise / performance)
+ Knock sensor
- 12* 2map
Apexi SAFC Neo
$430 delivered (new)
+ brand new interface
. 16*2 map
- no knock sensor
- no saved maps
Greddy Emanage Blue:
$516.51 delivered with harness
+ 16*16 map
+ Ignition Control
+ injector control
- no saved maps/profiles (???)
- apparently the timing adjustment is not great
- has issues with heating up coils (???)
Greddy Emanage Ultimate:
$722.91 delivered with harness
+ ignition control
+ injector control
+ 2 saved maps with quick flick switch to swap between.
+ auto tune (not a huge help, but worth mentioning)
+ extra inputs for mapping of many other car functions
- not a replacement ecu
Apexi Power FC (included for reference)
~$1200 with hand controller (2nd hand)
+ complete ECU replacement
+ complete control over engine
- Difficult to source these days
- $600 to tune.
2nd hand PFCs are like $800 via slidewize imports
he is a trader on the forums, speak to him
he should be able to get rb25 as well
tune should be $500 ish
or more like $400, shop around, plently of PFC tuners
theres no need to emphasise on multiple maps, you just tune the ecu the best and safest settings your car / engine can deal with. theres no need for a normal spec tune and a "race" spec tune. just tune with whats safe and be done with it. fuel economy will come from how you drive it and your foot on the pedal
im looking into all these options at the moment, i know info bout pfc but Emanage n that i cant find info on or opinions really.. what i cant find out is if emanage can run bigger turbos n that? its prob under my nose on this site but havnt come across it yet
ASK YOUR TUNER
a good indication of how good an ecu is the number of people who use it and documentation etc out there. if you cant find much on the emanage, chances are not many people use it. look at the pfc faq (in my sig) should give you an indication on the number of people that use the powerfc, and for good reasons too.
lots of documentation on the motec, for good reasons too
etc, if its good people will have documentation, howto's, guides etc
i dont think PFC's for the rb25's are as easy to come by as you think... which is why im considering these other options, especially since im only after 200rwkw... will pm slidewize though and see if he can help tho.
aside from getting a PFC, are there any other comments/feeback/info about the piggy backs i listed ??
last time i spoke with zac about the PFC availability he said it was fine and no problems with finding them, best to ask him. a 200rwkw well tuned r33 with PFC will run very nicely and have some good average power. the response and engine pickup is also much better as you are to tune the low load ign areas significantly. im about 12deg more advanced timing below 3 grand, so the car feels amazing to drive.
powerfc & alsd works fine, its just an official wiring change to make it work, its under the tutorial section, search for "active-lsd" in their and you will find it, its also in the PFC Faq
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
