Ive got an S15 R200 Helical LSD, and I would like to put it into my Series 2 Stagea RS four, which has an R200 non-lsd diff. Has anyone had any experiences with transplanting the S15 diff centres ? Im a bit concerned about the output shafts, as ive heard the S15 ones are unique, would it be interchangeable ??? thanks
Edited by chook
https://www.sau.com.au/forums/topic/151921-s15-helical-lsd-into-non-lsd-stagea/
thanks, that would be easy except that the S15 uses 3x2 bolt, 31mm dia, 30 spline output shaft, stagea is a 5x1 bolt, not sure size yet. guess if i can find a 5x1 bolt, 31mm dia, 30 spline output shaft ill be in business, ill check the wreckers.
chook..
Check out the R34 GT N/A variants and see what half shafts they run. You 'may' be in luck.
If not you will be selling the diff.
I looked in to dropping an S15 centre in to my R32 and found a set of compatible axles (don't remember exactly what they were off) BUT I opted against as the S15 rears are weak and tend to let go at around 200rwkw, god help it behind the rb30det.
Torque breaks things. :S
thanks, Nissan seems to have changed to the 30 spline shafts for the late models, are you sure they are weak, some people seem to say they used the same helical centre in the R34 GTR.
Fatz got a S15 diff into his old HR31 coupe (r200 longnose housing, being helical trpe LSD also)....
HR31 boys suffer the same issues, theres not much of a choice of aftermarket diff's out there compared to a short nose R200.
Will be interesting to see how you get on with it all....
Jez
666DAN, thanks, did you swap it for your viscous LSD and use your R34 GTT output shafts ? went straight into the S15 Helical LSD ?
the S15 is 30 spline, most pre-R34 skylines are 31 spline i believe, hopefully Nissan kept them uniform for the R34/ S15, thanks
Edited by chook
    • You have just offended every teenage boy in America
    • Structured text and other high level PLC programing languages are not allowable in Functional Safety. They are very difficult to audit. My PLC stuff is almost exclusively oriented towards Burner Management Systems which are a particularly pernicious form of Safety Instrumented System, when implemented in an SPLC. Even the part of the code written to work in the non-safety logic part of the PLC, like with a Siemens S7-1500 series, still needs to be treated as if it was safety code, with access restrictions, code fingreprints and the like. And Allen Bradley can go EABODs. They ae full of shit. They have this whole lie going on where they say if you use a ControlLogix controller and its IO, and then just duplicate the IOs (ie, run in series or parallel depending on type, to try to make it "fail safe") and "use these programming styles and place these restrictions on what you do" that you can achieve SIL2. What a load of crap. They just get away with it because no-one in the US seems to understand the first thing about Functional Safety and carries on as if all they have to do is buy only SIL2 rated equipment and hey presto, it's a SIL2 system. Idiots. /rant
    • If you're really considering leaving it, a great question to ask is, is the magnet going to stick to the sump? The answer to the above is the same answer towards if I'd have any level of comfort leaving it... Personally, based on the cost of a motor if the magnet were to cause damage, I'd be fishing it out either way. Use the methods in here. It fit in through the plug hole, it'll come out.   PS, get a small actuatable claw for a bore scope. OR if you know a vet, they have really cool controllable scopes with hooks on the end. Supposedly they're like playing a video game. Ask if they can acquire you one of their scopes... Engine oil after all is just a different type of lube right? Will only make it easier on the next dog or cat...
    • All other (Boolean) logic functions though, are just built on those blocks above. Which does give you a lot of functionality in logic. It is basing that on using thresholds with analogue signals like GTS alluded to.   Not having things like timers will make it less useful for some of the ramp up logic you'd want, and again, on Haltecs capacity specifically, I'm not across anymore what you can / can't do with different tables.   I'm assuming, with your logic you want to implement, not only do you want your timing safeties, you're wanting to be able to derive the duty cycle for your solenoid, to maintain I'm assuming 175PSi? Or are you using a standalone WMI controller to maintain the DC correct, and you just want the Haltech working out which fuelling maps you should be on?
    • It doesn't seem to follow revs. Oddly it seems to follow TPS a little bit from what I can see, but with some delay a bit. IE end of the graph, when he lets off throttle fully, pressure drops a lot, then slowly builds back up, but rpm is on a nice cruisey drop off. I do agree though, it seems very electrically.
