Hey guys I just my volk fzero rims on the weekend and turns out that the inside doesn't look so good with the car, so I'm gonna change the red to blue. Can someone give some hints or tips on the process? or should I take it somewhere to get it sprayed or something. I notice it's a bit difficult cos I cant paint over the words 'VOLK RACING'
I've also did a search and some steps were
1. sand back the rim with wet and dry (you will tell the difference when its sanded)
2. dry them with a cloth and a heat gun or hair dryier to fasten the drying process
3. wipe the rim with wax and grease remover, to remove any grease left on the rim
4. mask up the tyre with masking tape/newspaper so you dont get any overspray on the tyre's
5. spray 1 coat of grey primer (makes the paint stick/last)
6. after drying with heatgun or hairdryer, sand back the rim very lightly
7. spray 1 coat of colour as desired (mist coat)
8. dry with heatgun or hairdryer
9. apply 2nd and final coat of paint (second coat should be heavier than first coat)
10. after fully dry, spray 1 coat of clear
and this is from SYLNE.
any hints and tips would be grateful thanks!
Hey mate,
I really wouldnt attempt this on your own. your better of getting them professionaly done. You wont be able to achieve a great result from spray cans .
Edited by Silent
Depending on what colour your paint is, grey undercoat isnt always recommended.
i believe there are 3 primer colours grey/white/black
In your case i would use a grey or white undercoat depending on how light/dark the blue is, remember.. if you use a grey primer and your finished colour is a light blue might take afew more coats then usual to cover
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
