Just wondering who has/has used an ARC side mounted cooler, and what the experiences have been like relative to stock side mounts?
They are quite expensive retail, so ultimately if I was after one I'd be looking for one second hand, but first I'm just keen for some feedback on the quality.
If they really are as good as the price suggests it may be worth a shot, however I'm also aware of the benefits I could get from sticking an R34 side mount on to my R33 as QRI05E and others have shown, (and for just a fraction of the ARC cost).
So any feedback from those who have used them would be much appreciated.
https://www.sau.com.au/forums/topic/151926-arc-side-mounted-intercoolers/
Just how much better is the stock R34 SMIC over the R33 and R32 ones? I have an R34 and I am planning to get it to about 200rwkw and leave it at that - will it be safe enough to run the the factory item? I would rather not get a FMIC if possible.
Yer you should be able to get about 200rwkws with support mods on the stock FMIC with r34s
from all reports mate the stock R34 isn't such a bad unit and it should be able to handle 200rwkws.
Excellent - thanks guys. I can always rig up a water spray system for hotter days if there is a problem.
ARC SMIC replacement for a R34 GTT = 1700
ARC FMIC replacement for a R34 GTT = 1000
Ouch, Id like an ARC SMIC replacement, but look at the price, so much more expensive than a FMIC.
I wonder how much better a ARC SMIC would be compared to a factory R34 GTT unit.
yeah exactly - I've seen them a few $100 cheaper however what I'm really after is just some info on how they go. Basically, is the crazy price an accurate reflection of the quality?
I got the R34 ARC SMIC on my R33. The quality is incredible! It is a fair whack larger than the stock R34 and huge compared to the R33 one. Can't remember the exact sizes but the thing is FAT and barely fits in position. From memory it was ~11cm thick, 6 rows taller and 30% wider.
I'm hoping to take this thing to 250rwkw with a custom duct from the front bar, we'll see how it goes.
that's what I was thinking of doing tuitahi, R34 ARC replacement on to R33.
How many rwkws you got at the moment?
Depends on the dyno... but would be fair to say 200rwkw running stock turbo at 8 psi. Never dynoed at higher boost pressure but it pulls a fair bit harder.
Hopefully once the GCG VG30/RB25 hybrid hiflow goes on, the cooler will be up to the task of 250 or more.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
