just wanted to know if any of you had the same problem as me going through roadworthy,
They tried to do me for the "FACTORY DARK GLASS TINT". first up they didnt even know it was dark glass and wanted me to remove the tint, so i took my key out and gave it a little rub and showed them how easy it would be to remove it (sarcasm) lol...... then they wasted my time for two days telling me i had to replace the windows. eventually i got hold of the RTA and they faxed me the rules on factory Dark glass.
There is no tinted film fitted
The darker glass is behind the driver
The darker glass must have the marking "ECE R-43/00" and bear the symbol "V"
There are two external mirrors fitted.
now my numbers dont quite match up but that didnt bother the machanic tomuch, apparently the cops have imported a bunch of patrol cars with the same dark glass tint, and thus the reason for changing the rules.
if you guys have any hassles witch i doubt you will give us a PM and i will fax u the piece of paper i have.
https://www.sau.com.au/forums/topic/151943-nsw-stagea-roadworthy-tint/
Mine doesn't have any dark glass :wub:
Its all this greenish "UV Cut" kind of tint / film (?)glass all the way around.
I am kind of surprised that this would be a problem though, what about all the vans etc getting around with NO side windows etc at all and all the taxi's etc getting about with the advertising film covering the back windows? Wouldn't this be covered by the same set of rules?
I think you will find when a car is classified as commercial instead of private you are legally allowed to black out all windows behind the driver 100% ... This is why you see the vans windows all painted over or boarded up :)
Their mistake is thinking that it is a "modification" which it is not. The car was complied like that and to be complied the car must meet ADR's (pretty much), if a car meets ADR's it should be roadworthy, see where I am going here? It passes, it has to, you just need to prove it... Which you have nicely, just a shame it is such a pain. People are often painful just because they can be.
  • 2 months later...
its a bit like the vented bonnet issues... evo's are imported and complied with their vented bonnets, but technically they could get a yellow sticker once it leaves the pits are being registered, as it has a vent that would allow liquids to cover the windscreen in the event of a split hose, etc...
i doubt many of you would even get looked at twice by police though, let alone them have enough reason to give you a yellow sticker for factory glass..
yeah its not really about getting a yellow sticker though its more about trying to get it through road worthy if you are registering for the first time or registering in a new state.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
