I only got one reply in the styling section which wasn't much help (no offence) so i thought i would post my question here
I'm gonna get some new rims, finally, I'm just looking for some recommendations, i want them to be a grey shadow colour as i think that would suit the two tone colour more then a chrome silver would. I'm more into the performance side of the car so what size tyres rims would suit for better take off/power to the ground.
I'm also thinking a deep dish might look nice
thanks for any help
btw, this is the offset i got of maggala.com
front - 18X8.0 +33 225/40 R18
rear - 18X9.0 +39 255/35 R18
Edited by Hulk1010
That wheel looks nice - I've found with my 33 that you need the biggest diameter, width and dish you can fit to make them look good. 33's are a hard car to get the right rims for - I think I stuffed up when I bought mine.
Here's a link to tempe tyres packages.
http://www.tempetyres.com.au/products.asp?...2FSilver%2FGold
Edited by gtst25
Firstly, what is your budget? Are you after something local or jap?
My advice is to look at as many pics as you can from google...or try this site here...
http://www.hkskylineclub.com/images/Galler...GTS/page_01.htm
http://www.hkskylineclub.com/index1.htm
Click on the Members and Owners Ride links..plenty of examples there...
Wheels are like women and shoes....you never know how good or bad they look until you try them on ;)
thanks for any help
Dish :/
Edited by CCCP
33 look hot with dish! and your right the sure do need a big size to fill them out to look just right, heres a pic of my friends 33 with 18s with dish looks hot.
i reckon volk gt-n's look tuff as but cost a pretty penny!
thanks for the replys so far, another question i have is, do the front rims have to be a different width size to the back rims, I see many people have a one inch difference between the back and front rims, does it matter for example if the fronts are the same as the rears, 8 inch front and back?
Your car came factory with all four wheels of same width...yes its fine. Staggered width is just a personal preference, being RWD cars, having wider wheels at the rear gives tht added traction and also looks cool :D
Your car came factory with all four wheels of same width...yes its fine. Staggered width is just a personal preference, being RWD cars, having wider wheels at the rear gives tht added traction and also looks cool :P
Also means you cant rotate your wheels for maximum tyre life :happy:
what do u guys think of these?
http://www.tempetyres.com.au/products_clos...amp;part_no=298
also it says - (Deep Dish on Rear) - does this mean the fronts aren't deep dish?
Deep dish pack means the rears are wider and allow for more dish. The fronts still have a bit but I wouldn't go calling it deep dish :thumbsup:
You kidding anything higher than 18 is too big? even 19's sometimes look small on a 33!
These are the rims i got on mine, 19's 8.5 all round and i think they look a pretty good size. IMO 18's dont fill the arches enough, and with 19's you can still lower the car enough so it doesnt look like a 4WD.
If your outer rolling diameter has increased, did you then re-calibrate the speedo?
they are Envy MK II's, cost about $1200 for the rims.
I just put them on and got a wheel alignment, no speedo re-calibration, but ive noticed barely any change in my speed vs speedo. It would only been very little, probably insignificant anyway.
i like those mkll, but i found out they only come in a 18 x 8 in the gunmetal look ( i don't wanna go bigger then 18's) , i'm comming across a few different rims i like but they all seem to be 18X8. so i might just go with the 18X8 for all four wheels
    • For me at least the reason why it bothers me is because it's indicative of a deeper problem. And that will nag at me forever. Especially because I have tailpipe emissions testing + evap leak testing every 2 years.
    • WELP. I went to the track, and I suppose it went okay because any time you can drive home is okay. You may notice the car is not on the circuit in this picture. It was about 35C day out in Benalla which means the track was approximately the surface of the sun, probably. Good things, car did not overheat but it _was_ warmer than when I had done track days in similar heat before, I think, I'm not sure - I can't quite remember. Coolant got to ~105 via the ECU after 20-30 minutes of belting it in said heat. Oil got up to 145C in one instance which is pretty crazy due to oil cooler. Pressures were fine. I seem to remember this not getting quite so high before the vents. More HMMMM'ing to be done. On the subject of HMMM'ing, can anyone identify the sounds in the video below, you will know which ones I mean: https://www.youtube.com/watch?v=uj3BkI2cbTc I included some 'normal' sound as a reference for the first minute or so. The microphone in this instance was where the license plate is. It stopped working later in the day which is why my "best example of a lap video (not produced)" had internal audio - Isn't hearable from inside the car. I don't mean the chirping of the un-bedded/badly bedded track brakes which you can only hear while braking... Thoughts, brains trust?
    • blame old mate Hawkins for that one  I remember way back in the day the japanese didn't want them either... they always assumed a race shell would be thrashed. We found a few when looking for an R34 GTR for the Whites to drive in Targa Tas back in 2002.
    • I know it's probably not going to cause any major engine issues. I just had a more generic concern that it's technically not running right (I guess this means the rpm is not sitting where it technically should be) Though the other thing is, it's that my steering wheel is shaking at 1,100 rpm at idle until it gets warm (seemed to happen after I tightened my alternator belt, will be testing the alternator soon).
    • I mean, what's the concern here? Higher fuel consumption? FWIW my idle sits at around 800rpm or so as well. And yes, it runs fine, idles fine and there are no issues as far as I can tell. I don't quite see the problem.
