  • Replies 58
serious? they can do it just like that? that means they can epa any sports car.......
It seems so yes....
does it say why you have to go ?? like wat they rekon your car has ?? or do they just say you have to go ?
It's just a standard letter from the EPA, stating that "The vehicle does not comply with the standards for registration." And has "excessively loud or faulty exhaust system"
In relation to that, may I ask what EPA includes? cost, and where I can get RWC cheap?
Thanks
Yeah as said mate... it's just a noise test. Costs about $45, been through my fair share over the years with my cars. Just make sure it is under 91 decibels before taking it in or else you'll be wasting your money.
I had a policeman copy down my rego details recently when I was pulled into a breath testing station. I have no idea why.
they do that to see if your car is registered and you have no outstanding warrants/fines etc...
I had mine done the other day, and i was told 86db was the limit for 85+ model cars :D
Edited by 123456
I read somewhere that there was some law that if you live XX km away from that mcleod place then they can't send you there....is that true or do you just have to go somewhere else for your EPA?
a mate from shepp got sent to mcleod
http://epanote2.epa.vic.gov.au/EPA/Publica...6;FILE/1031.pdf
Section 11
Edited by Savage Bliss
He should have learned to read the fine print. :)
The last EPA letter we recieved had some tiny print on it, saying that if the vehicle was registered at an address which was more than 40k's from the testing facility, that the test wasn't compulsory.
This is only in the event of a "full" EPA test, not related to noise/smoke etc.
Keep in mind this letter was over 12 months ago, they may have changed things since then, business is good for the EPA, so it wouldn't shock me if they've opened a couple of rural testing stations by now.
...but read the fine print.
Always read the fine print.
They make it tiny for a reason!
One thing I don't understand is this (from the PDF link posted by Savage Bliss)
It is an offence to own or use a vehicle fitted with a
temporary defeat device, inlet port restrictor,
exhaust port restrictor or temporary noise reduction
device. These devices, when fitted to the exhaust
system, can temporarily and easily change or vary
the level of noise emitted from the exhaust.
Examples include variable exhaust restrictors, cut-
outs, bypasses, adjustable/variable/sliding
openings on mufflers, restrictive or temporary insert
plates and steel wool.
How is it possible then that Aston Martin's, Lambo's, Corvettes and probably a whole host of other exotics have exhaust butterflies as standard?
Farken load of crap.
Cheers,
matt
While I couldn't agree more I think the sticking point is "....vehicle fitted with a temporary defeat device." All the devices mentioned are removable whereas the butterfly valve is a permanent device.
So if I fit an apexi butterfly valve (or whatever they're called) before I get done, it's OK, but if I fit it after I've been done, it's not allowed? :(
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
