  • Replies 58
serious? they can do it just like that? that means they can epa any sports car.......
It seems so yes....
does it say why you have to go ?? like wat they rekon your car has ?? or do they just say you have to go ?
It's just a standard letter from the EPA, stating that "The vehicle does not comply with the standards for registration." And has "excessively loud or faulty exhaust system"
In relation to that, may I ask what EPA includes? cost, and where I can get RWC cheap?
Thanks
Yeah as said mate... it's just a noise test. Costs about $45, been through my fair share over the years with my cars. Just make sure it is under 91 decibels before taking it in or else you'll be wasting your money.
I had a policeman copy down my rego details recently when I was pulled into a breath testing station. I have no idea why.
they do that to see if your car is registered and you have no outstanding warrants/fines etc...
I had mine done the other day, and i was told 86db was the limit for 85+ model cars :D
Edited by 123456
I read somewhere that there was some law that if you live XX km away from that mcleod place then they can't send you there....is that true or do you just have to go somewhere else for your EPA?
a mate from shepp got sent to mcleod
http://epanote2.epa.vic.gov.au/EPA/Publica...6;FILE/1031.pdf
Section 11
Edited by Savage Bliss
He should have learned to read the fine print. :)
The last EPA letter we recieved had some tiny print on it, saying that if the vehicle was registered at an address which was more than 40k's from the testing facility, that the test wasn't compulsory.
This is only in the event of a "full" EPA test, not related to noise/smoke etc.
Keep in mind this letter was over 12 months ago, they may have changed things since then, business is good for the EPA, so it wouldn't shock me if they've opened a couple of rural testing stations by now.
...but read the fine print.
Always read the fine print.
They make it tiny for a reason!
One thing I don't understand is this (from the PDF link posted by Savage Bliss)
It is an offence to own or use a vehicle fitted with a
temporary defeat device, inlet port restrictor,
exhaust port restrictor or temporary noise reduction
device. These devices, when fitted to the exhaust
system, can temporarily and easily change or vary
the level of noise emitted from the exhaust.
Examples include variable exhaust restrictors, cut-
outs, bypasses, adjustable/variable/sliding
openings on mufflers, restrictive or temporary insert
plates and steel wool.
How is it possible then that Aston Martin's, Lambo's, Corvettes and probably a whole host of other exotics have exhaust butterflies as standard?
Farken load of crap.
Cheers,
matt
While I couldn't agree more I think the sticking point is "....vehicle fitted with a temporary defeat device." All the devices mentioned are removable whereas the butterfly valve is a permanent device.
So if I fit an apexi butterfly valve (or whatever they're called) before I get done, it's OK, but if I fit it after I've been done, it's not allowed? :(
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
